Traction Front Weights on 4R with Loader
/ Front Weights on 4R with Loader #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
Anyone have options for suitcase weights, or other ways to add weight to the front of a 4R series tractor that is equipped with a loader?
/ Front Weights on 4R with Loader #2
I wanted more weight on front probably 5 years ago, found some suitcase weights for my Kubota on CL and was very happy, until I went to move some snow and discovered that I could not lower my FEL all the way down without hitting the weights. I almost modified the loader but decided not to. Since then, we have paved our driveway and I use a walk behind snow blower to clear it.
I don't think it would be too hard to make a custom mount for some weights, but for me, factory stuff did not play nice together.
/ Front Weights on 4R with Loader #3
If you're having to spend money on weights, personally I'd put that money toward a grapple.
That brings up a new question, glad you mentioned it. I nearly forgot that I ordered a 4-in-1 bucket, awaiting arrival. Wonder how much more it weighs than the normal bucket?
/ Front Weights on 4R with Loader #5
Not sure. I think 72" bucket on my tractor weighs somewhere around 250 lbs, maybe 300. Add extra cylinders, cutting edges, hinges, gussets...likely over 100 lbs extra as a WAG.
Couldn't find the weight of the regular bucket, so you filled in that blank.
I saw on some site that the 4-in-1 weighs 425lbs.
Perhaps that extra weight far forward will be enough to give extra ballast for the front when I have that heavy MX8 on the back.
If not, thinking about foam filling the front tires.
/ Front Weights on 4R with Loader #7
I would go outback and get a bucket full of dirt and maybe wet it down with the garden hose. I'm guessing you don't have a place like that in your farmyard??
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2009 PETERBILT 365(INOPERABLE) (A67714)
2009 PETERBILT...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
