Traction Front Weights on 4R with Loader
/ Front Weights on 4R with Loader #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
Anyone have options for suitcase weights, or other ways to add weight to the front of a 4R series tractor that is equipped with a loader?
/ Front Weights on 4R with Loader #2
I wanted more weight on front probably 5 years ago, found some suitcase weights for my Kubota on CL and was very happy, until I went to move some snow and discovered that I could not lower my FEL all the way down without hitting the weights. I almost modified the loader but decided not to. Since then, we have paved our driveway and I use a walk behind snow blower to clear it.
I don't think it would be too hard to make a custom mount for some weights, but for me, factory stuff did not play nice together.
/ Front Weights on 4R with Loader #3
If you're having to spend money on weights, personally I'd put that money toward a grapple.
That brings up a new question, glad you mentioned it. I nearly forgot that I ordered a 4-in-1 bucket, awaiting arrival. Wonder how much more it weighs than the normal bucket?
/ Front Weights on 4R with Loader #5
Not sure. I think 72" bucket on my tractor weighs somewhere around 250 lbs, maybe 300. Add extra cylinders, cutting edges, hinges, gussets...likely over 100 lbs extra as a WAG.
Couldn't find the weight of the regular bucket, so you filled in that blank.
I saw on some site that the 4-in-1 weighs 425lbs.
Perhaps that extra weight far forward will be enough to give extra ballast for the front when I have that heavy MX8 on the back.
If not, thinking about foam filling the front tires.
/ Front Weights on 4R with Loader #7
I would go outback and get a bucket full of dirt and maybe wet it down with the garden hose. I'm guessing you don't have a place like that in your farmyard??
2021 Global Trailer (A61568)
2021 Global...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
2000 VANTAGE TRAILER END DUMP TRAILER (A60736)
2000 VANTAGE...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
