Kubota D600 engine + Harbor Freight generator
/ Kubota D600 engine + Harbor Freight generator #1
fatjay
Elite Member
Eastern PA
Not enough
I'm looking to build a diesel generator. A kubota D600 out of a grasshopper showed up on craigslist, and I was thinking of pairing it with this generator from harbor freight.
Will the kubota run at 3600rpm? I'm seeing conflicting information on sites. Also some list it as 14hp and some at 18.
/ Kubota D600 engine + Harbor Freight generator #2
Why not gear the generator to the motor so the diesel is running a bit slower?
Do you need MAX power out of that generator head?
SR
I haven't been able to find the power curve for that motor. The motor is out of a grasshopper 1822d which is 18hp from what I found on the net.
I don't know that I'll need the max but I'd like to have it available if I need it. I'll be running the whole house on the gen which means furnace, well pump, washer, dryer. It's not uncommon for me to lose power for multiple days at a time. My hot water is my furnace and I have baseboard hot water which involves a pump for the water.
The plan is to tie it into my heating oil tank which would provide enough fuel to last me a while. My primary source of heat is wood, furnace is a back up and for hot water.
/ Kubota D600 engine + Harbor Freight generator #4
You might have a problem with the output shaft bearing on that gen.
It might be designed to be coupled to engine rather than belt drive. ??
Direct engine works for me too. I saw in the gen reviews people putting pictures of a double pulley, and a few people talked about success with that in the reviews, so I think I should be ok either way. I'm fine with couple it directly to the engine, as long as I have a way to do so.
Seems the D600 makes 18hp at 3600rpm, however it might be a bit hard on the engine. 16hp it looks like is at 3200rpm, so I would need to size up a slightly smaller pulley on the gen to put it at 3600rpm.
/ Kubota D600 engine + Harbor Freight generator #6
How to get around a pulley on the gen shaft would be to couple it to a jack shaft running on pillow blocks.
Then you could adjust pulleys for what ever rpm you wanted.
/ Kubota D600 engine + Harbor Freight generator #7
OR put a properly geared "gear box" on the generator head.
SR
I don't know what a jack shaft or pillow block is. I don't know what the driveshaft side is like or how to adapt it to the gen. I'm still figuring this stuff out.
/ Kubota D600 engine + Harbor Freight generator #9
Kubota makes their own diesel gen sets which run at 3,600 rpm.
KUBOTA GENERATORS | PRODUCTS | Specifications : GL Series : U.S.A.
There is also a marine version which is rated at 3,600
Beta Marine Canada - Standard Engines
For satisfactory generator operation, the engine needs to be running on the downward slope of its torque curve so that if it slows slightly under load the available torque is increasing.
Starting to try and run the engine slower means you may be at a point on its torque curve where the torque falls off as rpm's decrease which can lead to a sudden stall.
I apologize for resorting to technical jargon to make a point but it is critical in generator operations.
The torque curve shows a downward slope as it goes from 2,800 to 3,600 rpm.
If you have the engine rpm's in that range and the load on the generator increases as the engine starts to slow down from its 3,600 rpm needed to produce 62 cycle AC, the torque output of the engine increases so it accepts the extra load without any fuss.
If you think it is a good idea to slow the engine down and use pulley's and V belts to turn the generator head at 3,600 rpm, you are now operating on a place on the engine torque curve where a slight lowering of engine rpm produces less torque and this situation quickly deteriorates into the engine stalling.
You need 2 HP to produce 1 kW of electricity. so in your case to turn the HF gen head you need at least 20 pto HP which you do not have.
Yes you can run the gen head with less engine power but not with a stable output.
Some engines are designed with a tapered shaft specifically for powering water pumps, generators etc, If this engine has a tapered shaft it is not the best for your application as lots of fiddling will be needed.
Dave M7040
/ Kubota D600 engine + Harbor Freight generator #10
Dave M7040
That's not true, AS LONG as you don't try to pull more out of the generator than the max rated hp of your engine.
I run a 15kw gen set with a 12.5 hp diesel, and it works perfectly as long as I don't try to pull over the rated hp of my diesel.
IF, I need more generator power, I use a bigger diesel to power it.
I've run my putters, tv, fridge and everything else, it works perfectly...
SR
I get the 2hp to 1kw, 18hp should be sufficient to 9kw. If you look at the specs they're only 2 30a breakers anyway, which is 7200w, which is exactly what the rated wattage is, if its exceeded it'll just trip the breakers.
If the engine is in good shape it should handle 3,600rpm just fine. I'll rebuild it over the winter either way. The engine isn't a tapered shaft, it's likely a keyed shaft. I'll get more details, but it was a front mount mower.
Kubota gensets are pretty much out of my price range, or any diesel generator for that matter.
/ Kubota D600 engine + Harbor Freight generator #12
Probably a bolt on stub shaft to the flywheel...
I'd want to make sure I got as much of that, I could get with the engine when I was buying it.
SR
/ Kubota D600 engine + Harbor Freight generator #13
Dig around on tractordata,, that engine pops up.
TractorData.com Kubota G52 tractor engine information
14HP at 3200rpm,, ask a local diesel engine shop if that engine can run 3600 rpm, that would get you more power.
If it were me, I would install the pulleys and run it, and enjoy.
I have a 10KW generator, but, I have it on a 60 amp breaker.
That works perfectly for me,, I can even run the electric hot water heater, and the well pump.
CADplans I saw that, but apparently there's a couple versions of this engine. This one in particular is out of a GrassHopper 1822D. From what I have found it's detailed here: Model 1822D Grasshopper Mower Parts Diagrams -The Mower Shop, Inc.
I've seen 14, 15, 16, and 18hp versions of this engine. This one is supposed to make 18hp at 3600rpm though. It's just hard to find info on this mower, I wasn't able to find it on tractordata.com which is my normal go-to.
/ Kubota D600 engine + Harbor Freight generator #15
Some reading material from a different site:
Kubota G52 / D6 for generator project
I have a D600 in a mower and when the mower dies, the engine will go to genset duty. I'll use the existing sheaves on the engine that drive the deck to drive a 5kw 2 bearing alternator:
Central Georgia Generator (CGG) -- Generators Brush Type
and locate the right diameter sheave so that the engine can run at 2600 RPM and the alternator at 1800.
My experience with a couple of these Kubota mowers is that if you run the just under wide open, the fuel consumption drops noticeably. Coupling this engine to a 5kw alternator will give you enough head room in the hp area that you're not going to over stress the engine and running the engine at 2600 RPM should give decent fuel consumption.
Jason
/ Kubota D600 engine + Harbor Freight generator #16
Diesel engines set up for generator use have different governor spring setups than a normal industrial or agricultural engine.
The governor overrun curve is very steep so that any load fluctuation will have minimal effect on engine rpm. Regular commercial applications have a more gradual overrun curve.
The generator applications have more isochronous like characteristics.
Simply put, if you aren't running the generator on a very steep part of the curve, you can't maintain 60 Hz output.
Not to say you can't make it work after a fashion, but you'll have dirty power.
/ Kubota D600 engine + Harbor Freight generator #17
get on govdeals.com and buy a big one on auction
Sadly this project was abandoned for now. The D600 sold before I could get there, but I found another 3cyl 21hp diesel motor that I picked up for $500, but it came with an entire kubota zd21 zero turn mower, which only needed one hydro rebuilt, and I couldn't justify scrapping the whole mower for the motor, so now I'm rebuilding the mower.
Thanks all for the info, I'll stick with my gas gen for now, and revisit this in the spring.
Problem with those is they're typically 40kw or some huge number, well surpassing my needs, which comes with a negative side effect of having much higher fuel consumption.
/ Kubota D600 engine + Harbor Freight generator #20
I also see pretty good deals on diesel gen sets, and they also are waaaaaaay to big, no doubt that's why they are cheap!
There's NO WAY I'm buying the fuel for a 30, 40, or 50kw genset!!
SR
case 370 glass door never installed (A61307)
case 370 glass...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
26120 (A56859)
26120 (A56859)
2012 Volkswagen Passat Passenger Car, VIN # 1VWBH7A33CC033108 (A61165)
2012 Volkswagen...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
