Trying to construct a 3rd function
/ Trying to construct a 3rd function #21
I used one of these ; Shopping
Hoses locally, fittings and disconnects from ebay. Tractor came from factory with button on FEL handle and wire ran through shaft.
Simple and cheap install.
Here is what I have for parts so far.
1/2" npt plat face couplers $38.95
1/2" NPT FLUSH FACE QUICK COUPLER SET ISO 1628 | Quick Coupler Pairs | Hydraulic Quick Couplers | Hydraulics | www.surpluscenter.com
1/2 npt x 3/8 npt hex nipple $1.75 ea(2) $3.50
1/2 NPT x 3/8 NPT HEX NIPPLE | NPT Male to NPT Male - Hex Nipple | NPT to NPT | Hydraulic Adapters & Fittings | Hydraulics | www.surpluscenter.com
JIC 6m x 3/8 nptf bulkhead $2.40 ea(2) $4.80
JIC 6M x 3/8 NPTF BULKHEAD CONNECTOR | JIC Male to NPT Female Straight Bulkhead | JIC to NPT | Hydraulic Adapters & Fittings | Hydraulics | www.surpluscenter.com
JIC 6 bulkhead lock nut $0.45 ea(2) $0.90
JIC 6 BULKHEAD LOCK NUT | JIC Bulkhead Lock Nuts | JIC to JIC | Hydraulic Adapters & Fittings | Hydraulics | www.surpluscenter.com
3/8 x 108 JIC 6F swivel x JIC 6f swivel SAE 100R16 hose $24.95 ea(2) $49.90
3/8" X 18" JIC 6F Swivel X JIC 6F Swivel SAE 1R16 HYDRAULIC HOSE ASSEMBLY 5 PSI | Hydraulic Hose Assemblies | Hydraulic Hose and Hose Assemblies | Hydraulics | www.surpluscenter.com
JIC 6m x SAE 6m Swivel 90 elbow $2.20 ea(2) $4.40
http://www.surpluscenter.com/Hydrau...IC-6M-x-SAE-6M-Swivel-90-Elbow-9-6801-6-6.axd
1 station DO3 subaplte open center $35.95
http://www.surpluscenter.com/Hydrau...STATION-DO3-SUBPLATE-OPEN-CENTER-9-5883-1.axd
12 VDC 10 GPM OC solenoid valve $128.15
http://www.surpluscenter.com/Hydrau...12-VDC-10-GPM-OC-DA-SOLENOID-VALVE-9-6136.axd
Hirschmann Connector $4.80 ea(2) $9.60
http://www.surpluscenter.com/Hydrau...-Accessories/HIRSCHMANN-CONNECTOR-11-2457.axd
12 VDC winch motor control pendant $19.95ea (2) $39.90 (at this price I wanted a spare)
http://www.surpluscenter.com/Electr...2-VDC-WINCH-MOTOR-CONTROL-PENDANT-11-3492.axd
Thats the parts for the added valve section, in the basic order from the grapple back. This is to connect power beyond from the loader valve to the DO3 subplate.
1/2" NPT female swivel $2.50
http://www.surpluscenter.com/Hydrau...el-Union/1-2-NPT-Female-Swivel-9-1405-8-8.axd
1/2" x 36" 1/2 nptmx 1/2 nptm SAE 100R16 hose $11.95
http://www.surpluscenter.com/Hydrau...Hydraulic-Hose-Assembly-4000-PSI-917-2236.axd
SAE 6M x 1/2 NPTF adapter $2.85ea
http://www.surpluscenter.com/Hydrau...ight/SAE-6M-x-1-2-NPTF-Adapter-9-6405-6-8.axd
This connects the return line to the tank to the DO3 subplate.
SAE 6M x 1/2" nptm connector $1.80ea
http://www.surpluscenter.com/Hydrau...ht/SAE-6M-x-1-2-NPTM-CONNECTOR-9-6401-6-8.axd
This comes to $335.15, with shipping is $363.04. I wanted to post this to make sure I was on the right track and try and help someone else in the same boat. This forum has been a HUGE help to me and I wanted to try and return the favor. Only thing I may change to my knowledge is the hose lengths once I pick up my grapple tomorrow from my tractor dealer and check my measurements. All depends on if that switch I found will work.
/ Trying to construct a 3rd function #24
I went with this valve and the same do3 sub plate your looking at
12 VDC 21 GPM ARGO RPE3-6 DA HYDRAULIC DO3 SOLENOID VALVE | Solenoid Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Only reason was it was able to handle a much larger flow and pigtails instead of a bulky connectors. I have been very happy with it for the past 6months, its a very good quality valve made in Europe. I also opened up the ports in my sub plate I wanted as little restriction as I could get since my power beyond circuit also runs my backhoe when I have it mounted and if there is a lot of restriction it will create much more heat.
View attachment 518945 View attachment 518946
I looked at the same valve and liked it for the cleaner wiring just like you did. I was skeptical since I hadn't heard of them. One question on solenoid valves in general. Can the valve be mounted on the subplate so it aligns with either the work ports or the through ports? Or can it only be mounted one direction?
/ Trying to construct a 3rd function #26
To be perfectly correct they can only be mounted in one orientation (the pesky engineer thing again). That is to say only in one direction (like North-South vs East-West) and only one way in that direction.
There is a small pin on the bottom of the valve that sits into a hole on the subplate & the bolt mounting pattern is rectangular to prevent you from mounting it any way but one.
Another thing to point out, if you look at the pictures from Snowback that you linked earlier, he's using the W.R. Long kit and their subplate has ports on only two sides NOT one port per side like the subplate you have selected.
There's nothing inherently bad or wrong with what you have, I just wanted to make sure you noticed that not all subplates are created equal so to speak and that you are going to have to account for that with your mounting position and hose routing. Trying to eliminate the gotchas. ;)
As best I can tell W.R. Long is either making their own subplate or having it made just for them because I couldn't find anything like theirs after a couple good weeks of internet searches.
I did finally find one from Magnaloy that has ports on two sides but their design appears to be thicker (taller) that W.R. Long's and it's probably double the cost of the one you're looking at right now. That extra $$ buys a lot of 90 degree fittings LOL
Here's a link to a W.R. Long kit on a Kioti DK45 where they mounted the valve on the rear of the tractor (I never really liked that placement either but it's another good view of the valve & subplate and the port orientation)
http://www.tractorbynet.com/forums/kioti-owning-operating/331759-3rd-function-install-summary-dk40se.html
Oh and my one single best bit of advice - no matter how much help you get nor how much homework you do, something will still go wrong, you'll find something you could have done different / better after you're done.
Just take a deep breath and roll with it - it comes with building your own system.
Found one possible hiccup. I was looking at the loader manual and lists a pt1/2 for the fittings, after a quick google it brings up a bspp thread and not the npt thread I thought it was. Does anyone know what size the thread and hose size is on the power beyond of a 2538? Just want to make sure I didnt screw up.......yet.
Still trying to figure out the switch part of the puzzle. It was suggested to use an atv winch switch but cant find one that Im sure will work. I have googled and read what I can but they all seem the same to me. I found one that would be easy to mount and use but I was told it would not work, so here I am asking what to get. They all seem to work just fine with a winch but not a 3 position hydraulic valve. Could someone please point me to what I need to buy? Can they be wired direct or is the relay needed to make it work like I need for a 3rd function? Thank you in advance.
/ Trying to construct a 3rd function #29
I used a standard a tv winch switch because they are waterproof. For the grapple, up position opens grapple, drown position closed. I also used to work a diverter valve on the rear...i bussed both wires together for it.
They work great for me and cheap.
Sounds good to me, thank you for the information. I like they way it mounts to the loader control. Get one like this?
12V Winch Rocker Thumb Switch w/ Mounting Bracket - Handle Bar Control Switch | eBay
Or do I need the whole package?
Contactor & Winch Rocker COMBO 12V Solenoid Relay Thumb Switch For ATV UTV New
Wish this one would work because of the way it would mount similar to the standard wr long handles used.
12 VDC WINCH MOTOR CONTROL PENDANT | Power Transfer Switches | Switches | Electrical | www.surpluscenter.com
/ Trying to construct a 3rd function #31
Just the switch...should be attachment point on valve. You'll need to tap power from somewhere..my fuse panel was right there and convenient.
Sounds simple enough, thank you again. Getting it all ordered now.
Do you by chance have a wiring diagram for that valve? I bought the same you did and it didnt come with anything and google isnt helping me find one. I have everything installed and plumbed, just need to get the wires connected, hopefully without frying something. Thank you.
/ Trying to construct a 3rd function #34
No wiring diagram needed just put 12v across the legs on the side you want to move does not matter on the polarity. On Mine I grounded 1 leg from each side then wired my +12v from my rocker switch top of rocker to one side and bottom of rocker to the other side 12v to the center of the rocker.
/ Trying to construct a 3rd function #35
Great info guys. I am in the process of doing the same thing with my tractor. I have the parts just need (I think)to install it. The below link is the valve and subplate that I have. I believe it is correct but would appreciate if someone could verify that for me. There are 3 connections inside the DIN connector for the wiring but it came with out a wiring diagram. I'm not sure of the exact configuration to wire this so help on that would also be appreciated.
12V DC Tandem Centre DO3 Directional Control Valve | Princess Auto
1-Station D3 Valve Subplate | Princess Auto
Update.......everything works! Took a little figuring out on the wiring part and getting a 12v line close by was a bit of a challenge but not bad for a couple evenings install time. Huge thank you to all that have helped me along the way........been researching and asking questions for a month. Considering what I saved, I dont regret it at all.
dealer installed $1200 plus tax
wr long kit $900 shipped
my kit $360 various shipping included
What you have looks good to me, but Im far from the expert on this.
/ Trying to construct a 3rd function #38
Good to hear it's all working. What did you finally use for your electrical switch and how did you wire it. I'm sure it's simple and I'm just missing something. Like I said there are 3 connections on each solinoid on the valve. I would have thought it should only need 2 on each solinoid
This is the switch I used.
Amazon.com: VIPER Replacement ATV / UTV Mini Rocker Handlebar Switch - All Winches: Automotive
On my valve there were 2 wires on each solenoid (4 wires total), I grounded one wire from each solenoid and the other 2 were were connected to the switch. The switch has 3 wires coming out of it, 1 red one goes to a 12v source and the other 2 are control wires (1 black and 1 green)that were connected to the 2 remaining wires from the solenoids. I just switched the black and green till the switch worked in the direction I wanted then crimped them together.
Here is a thread that cleared up a lot for me. Post #20 has a picture that helped me with wiring.
http://www.tractorbynet.com/forums/...lling-3rd-function-hydraulics-electric-2.html
I forgot to add this suggestion. I see you have a 2017 tractor, I dont know how close you are to your 50 or 100hr service but if you are planning to change the fluid I would do it after you install the 3rd function. With moving lines around and getting fittings tight enough I lost fluid getting everything done, but didnt really matter because I was changing it all anyways.
2019 FREIGHTLINER CASCADIA 125 DAY CAB (A63569)
2019 FREIGHTLINER...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
