Winch Question
/ Winch Question #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
I have just installed a cheap (HF) winch to use with a snowplow on my tractor.
There really is no place to attach the fairlead and I was wondering if it is REALLY needed?
Exactly what BAD things will happen if I don't put one on?
Knowing me, the winch will also see other uses as time goes by up until I find what it won't do.
/ Winch Question #2
Post a picture and then I can offer a comment.
Usually the fair-lead is needed when the direction of pull on the winch cable is not straight unto the drum.
Dave M7040
/ Winch Question
Dave M7040
Direction of pull will be straight up/down.
/ Winch Question #4
Looks like it will work for some stuff.
Generally the fairlead keep the cable from making a sharp turn on a "sharp edge". If you have straight pulls with light loads your good.
Some people do not realize the load on a winch. A winch should be rated at a minimum of 1.5 times what you need it for.
You need to be able to pull the full weight of the tractor plus all the dirt/mud it is stuck in, plus the loss of drum diameter pulling capacity. Remember the capacity is rated on the first wind.
/ Winch Question
If the Ford gets stuck, the 12,000# winch on the MF50 will get it out.
This one is just to pick up the plow for now.
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
Shamrock 10ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 10ft. S/A...
