Winch Question
/ Winch Question #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
I have just installed a cheap (HF) winch to use with a snowplow on my tractor.
There really is no place to attach the fairlead and I was wondering if it is REALLY needed?
Exactly what BAD things will happen if I don't put one on?
Knowing me, the winch will also see other uses as time goes by up until I find what it won't do.
/ Winch Question #2
Post a picture and then I can offer a comment.
Usually the fair-lead is needed when the direction of pull on the winch cable is not straight unto the drum.
Dave M7040
/ Winch Question
Dave M7040
Direction of pull will be straight up/down.
/ Winch Question #4
Looks like it will work for some stuff.
Generally the fairlead keep the cable from making a sharp turn on a "sharp edge". If you have straight pulls with light loads your good.
Some people do not realize the load on a winch. A winch should be rated at a minimum of 1.5 times what you need it for.
You need to be able to pull the full weight of the tractor plus all the dirt/mud it is stuck in, plus the loss of drum diameter pulling capacity. Remember the capacity is rated on the first wind.
/ Winch Question
If the Ford gets stuck, the 12,000# winch on the MF50 will get it out.
This one is just to pick up the plow for now.
2016 Crane Carrier Co. New Way Side Loader Garbage Truck (A61573)
2016 Crane Carrier...
Caterpillar 65-95E Tractor Service Manual (A63117)
Caterpillar 65-95E...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRACTOR TRUCK (A59912)
2019 INTERNATIONAL...
(2) 15 Gal Sprayers, 25 Gal Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gal...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
