Deere 710c backhoe hard start issue.
/ Deere 710c backhoe hard start issue. #1
tazz001
Gillett PA
John Deere dozer, Allis Chalmers tractor
90 Deere 710c has had start issue.
Has new batteries, cabling in good shape, new starter. extra ground cables put on. and still starts hard. It starts like the batteries are weak (yes new batteries have been tested).
It will crank better with the farm fix of wiggle the steering wheel so its seems like it's hydraulic related. It seems like the unloader solenoid is working (its on the main pump).
What has us really scratching our heads is there is a power steering pump that is belt driven??
Why would steering wheel jiggle work for starting issue?? I'm confuzzeld or are we overlooking something in the hydraulic system..
Can anyone please explain?? throw me some ideas
/ Deere 710c backhoe hard start issue. #2
Based on what you've described I would take the belt off the ps pump and see if the starting behavior improves. It could be something in the pump or valve restricting flow and causing it to run over relief all the time.
That is not happening. The main hydraulic pump will have to come off to remove the belts.. Which means removal of all the front end weights.. Possibly radiator..
Further research.. The parts manual calls the PS pump a steering charge pump..
/ Deere 710c backhoe hard start issue. #4
Looking through the parts diagrams it's more complicated than I was thinking. The belt drive pump must charge the main pump as well as the steering valve. There's a priority valve involved too and I haven't dealt with those before to try helping without a schematic. I'm sure there are others that will chime in though!
Complicated is putting it midly.. Public forum would frown on way I am thinking. 450b dozer needed new crank driven pump last summer.. That was bad enough..
Chased pressure line and it appears to go to steering..
/ Deere 710c backhoe hard start issue. #6
My knowledge of JD ind tractors is very limited but I do understand closed center hyd's. I don't understand the need for a steering charge pump on closed center hyd system. Turning steering wheel back & forth during starting process relieves pressure buildup and to my knowledge was originated by a JD representative not a farmer. What indicates destroker valve is operating correctly? Have you checked voltage to it? How did you check it's operation? It sounds to me that the de-stroking valve is inoperable.
/ Deere 710c backhoe hard start issue. #7
My guess is the belt drive pump through the priority valve charges the main pump but also supplies the steering valve which is probably an open center valve. Hence the name. Just a guess though.
/ Deere 710c backhoe hard start issue. #8
Not up on industrial either! So just a GUESS; "steering charge pump" pump may not be a steering charge pump, but a charge pump for the main pump, instead of an internal transmission pump that older JD AG tractors have. Since this is designed to sit in one place and dig for long periods of time.
/ Deere 710c backhoe hard start issue. #9
Zebrafive
Below is parts schematic of for 710C trans pump
/ Deere 710c backhoe hard start issue. #10
Zebrafive
Thanks, TxJim, as I said, I am not up on the Industrials, especially the one that did not "morph" from AG tractors.
/ Deere 710c backhoe hard start issue. #11
You would think if the tractor operates okay after starting, including power steering and loader/backhoe functions that this belt driven pump is okay.
I am with Jim and would check out the destroking valve as it would be the most likely cause of the problem. The main hydraulic pump is a heavy load on the engine, much more than the belt driven pump. I would hope the de-stroking plunger is the problem as it would be the easiest and cheapest thing to change/fix.
Pull the de=stroke out and check it for operation across the battery with a fused test lead. Then make sure the parts in the main pump are moving and not locked up.
/ Deere 710c backhoe hard start issue. #12
How does the observation of wiggling the steering wheel to increase starting RPMs fit with a faulty/stuck de-stroking valve? Not being a smart a@@, just trying to understand.
After some quick research of priority valves (but zero experience) it does seem possible for the valve to stick and cause the steering/charge pump to run higher pressure than normal. But I don't know which circuit (steering or main pump) gets "priority" and how that is implemented.
/ Deere 710c backhoe hard start issue. #13
texasranger556
I have no experience with the belt driven charge pump nor have a clue what it's purpose is. IMHO the stroke control valve doesn't get stuck but pressure leaks off of hyd system when engine isn't running therefore when attempting to start engine hyd pump is attempting to build pressure & wiggling steering wheel provides an outlet for the building pressure to go.
Jim
/ Deere 710c backhoe hard start issue. #14
I will have to ask my brother about this problem, since he does all the work on the 710c.
CATERPILLAR PAVER (A65053)
CATERPILLAR PAVER...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
