Loader Kubota B21 Clicking down hills
/ Kubota B21 Clicking down hills #1
sruder123
Mukwonago, Wisconsin
Kubota B21 TLB and Case 450 Crawler Loader
I have a B21 TLB and love it. Starting to notice from time to time that when I navigate down a grade, especially with a load in the bucket that I hear a clicking noise as the hydros keep the tractor at speed. Any ideas? IMG_0887.JPG
/ Kubota B21 Clicking down hills #2
tighten the wheels
Tighten the wheels? Clicking sound like it is under my seat.
/ Kubota B21 Clicking down hills #4
And the rear wheels are where????? They are near the seat......
Loose wheels are a good place to start and a cheap fix if you catch them early.
/ Kubota B21 Clicking down hills #5
And what happens when re-torqing does not stop? Mine has a creaking sound that seems to come from the wheels. However lug nuts are very tight. Should I loosen the lugs and then re-torque them?
/ Kubota B21 Clicking down hills #6
Do you have clamp on hubs???? It could be the hubs.
/ Kubota B21 Clicking down hills #7
Are the wheel lug nut holes "egged out"? because it wasn't caught in time? If so, you will need to replace the wheels or try to weld them up and redrill.
/ Kubota B21 Clicking down hills #8
Guess there's only one way to find out; I'll find out next week when I have time.
Not sure yet. Definitely not the wheels as the sound is under the counsel or rear of engine
/ Kubota B21 Clicking down hills #11
I finally investigated my creaking. Lug nuts very tight, so that wasn't it. Removed one wheel and discovered the hub easy loose, and the pins were gone. It's a wonder the wheels didn't fall off! I decided to move the hubs outward one hole, install new pins and tighten the wedge bolts. I did both wheels, and the noise was gone completely. An easy Fix, and I learned the wheel attachment system.
/ Kubota B21 Clicking down hills #12
I own a B21, don’t have clicking but can you tell me about moving the hubs outward?
/ Kubota B21 Clicking down hills #13
Not sure if the B2410 and your B21 are the same, but it was pretty simple. First, I looked to see which hole the pins were supposed to go through vs other holes in the axle. In my case, there was another hole in the axle outboard of the holes that should have had a pin through them (remember, I had no pins in use at all).
I jacked it up so one wheel was off the ground. Then removed the wheel lugs and the wheel. That exposed the hub. I loosened the bolt that held the hub on the axle and simply slid the hub outward to the next hole. Put the pin in it and tightened the bolt to keep the hub tight on the axle. Then put the wheel and tighten the lugs.
Then switch sides and repeat. The bolt that holds the hub on is the key to making this work. It is designed to wedge the axle against the hub. Fairly simple once you see it in person, but hard to describe.
Hope this helps you.
/ Kubota B21 Clicking down hills #14
Be 2410? Mine is a 2007 B21 I don’t see pins or holes in my axles. What year is yours or how do you tell the series of B21?
/ Kubota B21 Clicking down hills #15
I guess the 24 series and the 22 series are different... Can you see axle sticking outward of the wheels? If not, the wheels may be out as far as they can go. I'd strongly recommend finding a service manual for your series and looking there.
/ Kubota B21 Clicking down hills #16
At least one person reported back!!!!!!!!!!!
Did you have any attachments on the rear of your machine? I have a backhoe. Can this be done with that installed?
/ Kubota B21 Clicking down hills #18
It appears the person posting does not have a B21, so the comments only relate to his own machine, not your original question/problem/thread relating to your machine. A B21 has fixed axles.
When i looked under my machine it looked like a fixed axle. Which I knew what the noise is.
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2016 FORD F-550 SUPER DUTY (A60736)
2016 FORD F-550...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61307)
2006 Heil Tanker...
