Hello
/ Hello #2
G'day Danielle and welcome to TBN from Downunder.
Here's some quick information: TractorData.com Ford 82 tractor information
The Ford "800" is a series of tractors, so your Grandpa's tractor will be an 8xx (as in the above example 820). The site that I've linked to will have the information once you've looked and determined. Also, the serial number of the tractor will help to determine what year it was built.
Enjoy the site.
/ Hello #3
:welcome:
To the TBN forum Danielle. Glad that you decided to join us here.
You came to the right place as there are a lot of knowledgeable people here.
/ Hello #4
:welcome:to TBN Danielle...enjoy.
/ Hello #5
Hi, Danielle. Welcome to the forum!
I'm going to move this thread over to our vintage Fords section. :tractor:
/ Hello #6
Welcome.
Model & Serial number location on the left (sitting on the tractor) on the flat spot above the two holes, behind the starter. Posting a photo would also help.
Kirk
/ Hello #7
...and I am here trying to find out something about my grandpas ford 800 tractor
Welcome, Danielle. What is it that you're trying to find out (about your Grandpas ford 800 tractor)?
/ Hello #8
yep.. post pictures, the more the better.
It's very common to have parts swapped and replaced on these old tractors. tin and even the transmission. We can look at your tranny serial number and model ID, then look at the rest of the tractor and see if they match. Either way, we can tell you what you have.
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2020 Kubota...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59906)
2007 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
