LS G3038 Hydraulics
/ LS G3038 Hydraulics #1
missouriblue
St Robert mo
ls g3038
The housing for the control lever for the bucket and the 4 hoses that go down below by the foot speed control (?) get super hot while I am brush hogging. This is without operating the bucket controls. Is this normal?
Thanks
/ LS G3038 Hydraulics #2
Thanks
How hot? If the tractor is HST it uses the same hydraulic fluid for the HST and the Loader but with different pumps. There is always fluid flowing through the valve blocks even when not using the loader. It is recommended to run HST wide open to reduce heat. You might need to use 80% of mid range speed instead of 20% of high range.
Does not have HST. Have been told that is might be the filter.
/ LS G3038 Hydraulics #4
keep in mind that if the filter is causing that much restriction, chances are it could be bypassing the filter element. I would replace it right away!
John Deere 772-A Grader (A62679)
John Deere 772-A...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
New Holland TC29 Farm Tractor (A65579)
New Holland TC29...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
