Weight bracket on sx3100
/ Weight bracket on sx3100 #1
dslanec
Northern Michigan
CUB/YANMAR SX 3100
Does anyone have the front weight bracket on a sx3100 and if so do you like it? Can you use it and the loader at the same time? I am thinking about adding one for this winter to help with steering. I run a 60" Rear blower most of the time but also have a plow on the loader arms I use sometimes also. I do not want to put chains on the front. Last winter I cut/sipped the front tires and that did help some so I'm thinking if I add weight too that I'll be better off.
/ Weight bracket on sx3100 #4
Ah, like boat shoe sipes!
Are your tires loaded? I use windshield washer fluid, it adds weight without interference.
Yes my rear tires are loaded with beet juice. And in the winter I use chains on the rear so traction is not a issue. Now I am trying to get better steering without chaining the front tires which is why I'm asking about a weight bracket for the front.
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
International Harvester McCormick Farmall 656 Tractors manual and others (A63117)
International...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
