Homemade Grapple
   / Homemade Grapple #11
Oldpath, I sure am glad you posted. I've been trying to find where I heard this music for weeks!Wife thinks I am nuts.
Anyone have a clue to the name of the song?
   / Homemade Grapple #12
Thanks N2D, shortly after I posted I clicked on the u-tube video and read the whole intro where he gave credit for the music. Sad thing is that the artist passed away a few years ago from brain cancer. He was only 57.
Thanks again.
   / Homemade Grapple #13
Thanks again.
Well I have a confession to make, that's where I found it too. :D
I just did a search to find the one I posted to make sure it was the right thing.
Very sad about the artist, I hadn't had a chance to dig into him more yet.
   / Homemade Grapple #14
I had to email my daughter down Va. last night to see if she had a way of finding that tune, she found it. It has that ghostly mournfully sound to it, kinda like half hillbilly and bluegrass. I like it, you wont hear that on radio unless maybe satilite radio, good tune to build a grapple with. The title "It's raining the Blues" but why does it say for "Bill Monroe"?
   / Homemade Grapple #16
Thanks Oldpath, I didn't quite understand the the Bill Monroe part either. I just assume it was a sign of respect for him.
That grapple you built was beautiful. I built one similar using a land pride as a reference. I should have put gussets between the tines like you did though.
I kept bending my tines while moving some big rocks so last week I cut them off and welded a piece of 1/2" steel across them and welded on nine bucket teeth.
Funny story though, My neighbor lost a huge oak tree last year and 2 days ago I saw him and his dad starting to clean up the mess. I noticed they were sawing off the limbs and were using a small atv to pull them to the back yard so I offered them the use of my tractor and grapple and within about 4 hours they had cleaned up the entire mess.
Needless to say they were very appreciative and amazed what they could accomplish with this combination.
   / Homemade Grapple #17
Everyone's expectations are different in regards to a Grapple. I wanted the most versatility. I started by building the grapple on the FEL frame. I could switch buckets, etc., and the claws stayed with the FEL. Immediately realized that wasn't a good idea. So I bought a used Bobcat LoPro bucket and moved the double claw grapple to that. Can grip a very large pile of brush. Or odd sized objects such as rocks. Or haul a bucket of loose material. No change of tool required.
Tines are built from 1/2"x4" flatbar. Cylinders are 2"x8". I use the snot out of it. Had to recently rebuild the claw hinges. I didn't use bushings in the beginning, just swiveled the flatbar on pins.
   / Homemade Grapple #18
Very impressive, sure have those front tires squatted.
   / Homemade Grapple #19
If you add a Grapple to your FEL you will test it to the maximum as well as the front axle/tires of your tractor. I've carried many loads with one rear tire off the ground.
   / Homemade Grapple #20
I have a John Deere 245 loader for a John Deere 2240 Tractor. The loader has a grapple on it, there is a cage on top of the grapple that I would like to remove, need tines for the grapple, would like shorter tines. It has a hydraulic cylinder which I know I will either have to replace or move. see that attachment, just wondering if I cut the grapple arm will it be ok.
2019 Chevrolet Sliverado (A55973)
2019 Chevrolet...
2022 CAT skid steer (A55973)
2022 CAT skid...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
15200 (A56857)
15200 (A56857)
17101 (A55787)
17101 (A55787)
