Ballast for 4720
/ Ballast for 4720 #1
popsie
Member
Southern ,ohio
john deere 1026r, john deere 2030, ford 8n,Massey ferguson 230
Does anyone know if I can load tires with rim guard and have 2 wheel weights on each rear tires at the same time?i have r4 tries. H180 loader.
/ Ballast for 4720 #2
popsie
Don't know of a reason that it wouldn't work well for you.
/ Ballast for 4720 #3
I have three 110 lb. weights on each rear and filled with WWF a drum in each tire. No problems so far with the 4520.
/ Ballast for 4720 #4
This is what is listed in the H180 loader operator's manual:
All of the following requirements are necessary to prepare the tractor for loader operation:
H180 MSL:
1600 mm (63 in.) or greater rear tread setting.
Rear tires filled with liquid ballast.
Four rear wheel weights.
380 kg (836 lb) minimum 3-point hitch ballast.
H180 NSL:
No rear wheel weights
For fluid filled rear tires: Fill tires 3/4 full using a calcium chloride mixture of 1.6 kg (3.5 lb) per 4 L (1 U.S. gal) of water
Deere 310SK (A57148)
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2022 John Deere Z930M (A57148)
2022 John Deere...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
