wheel loader lift high speed only
/ wheel loader lift high speed only #1
maxpax
sweden
ChangLin ZLM15B
Hi.
I am close to buying a chinese changlin zlm15b from around 2008. The loader on it is a bit annoying when lifting, it's not possible to lift slowly by pulling the lever a little bit, pulling it and coming 'bout half way suddenly it jerks up in high speed. Same with raising the tilt. However, when lowering the loader (and/or tilt) it's perfectly controllable and possible to lower slowly och fast by choice. Everything else in the hydraulics works good.
So, the question for people who are experienced with hydraulics is what comes to mind first? I have just started to learn about hydraulics and my thought would be maybe a wrongly mounted flow control valve or something. Any ideas on how to achieve a controlled lifting motion?
/MaxPax
/ wheel loader lift high speed only #2
My guess would be the valve is not made correctly to allow for feathering smoothly. When you move the valve a little bit, before it starts lifting, does it sound like it's loading the pump? I have one valve that blocks the pump flow before it opens the port to the cylinder, so it's all or nothing to the cylinder.
You could try reversing the hoses to the cylinder to see if it lifts smoothly. If it does that would eliminate any other problem in the system.
Some valves just aren't made very well.
Thanks for the answer!
As I remember now it doesnt sound like the pump get loaded before, but the whole machine has quite much sound to it so the sound from the hydraulic pump might be drowned by the engine and loose plates. I will definitely try to swap the hoses if (when) I buy it and get it home.
/ wheel loader lift high speed only #4
Does the loader stay up once raised or does it drift back down? Only been around one chinese wheel load and the valves on it were very poor quality. Wouldn't feather very well, allowed the loader to drift down very rapidly, etc.
It does not drift down at all.
/ wheel loader lift high speed only #6
Can you tell if the valve is controlled via mechanical linkage, hydraulic pilot joy stick, electric proportional. Hydraulic pilot and proportional could have a control issue causing the problem
Yes.
The valves are right in the cabin and there are two levers with one function each. I have not got the machine home yet, that might be in august...
Okay. Now I have the machine at home. :) I work a lot now so I'll check things more closely in the weekend coming or next week when work will not be so intense.
However, I moved it today and tried that which my friend the gravel-delivery-guy told me, to rev up the engine when working the lift/tilt. It kinda worked and not at the same time. The tilt could be slowly lifted with higher rpm, very nice! But - the boom arms or whatyacallit doesnt allow feathering even with high rpm. There's a pssss sound coming before the jerk so maybe it's the problem that bigdeano talked about...
/ wheel loader lift high speed only #9
They must use the same loader valves that Mahindra uses on some of their loaders. Does it say Besko on the valve? I'm replacing mine (to add a grapple function.)
Now I removed the cover from the valves and took some pictures:
IMG_20170728_151657.jpgIMG_20170728_151805.jpgIMG_20170728_152122.jpgIMG_20170728_152132.jpg
So, i went bananas with the chinese machine and tried some more with the lift/tilt. With the tilt I can fether but the range with the lever is very tight although the lever itself moves a lot before reaching the fethering spot so to speak. The "lift" is a bit worse, I move the lever, more, more, more, and next thing it starts hissing and the next thing it takes off. I can find a spot where it moves little but it is raising in steps, not slowly and controlled.
Maybe I can take the valve apart and change springs or something? And, does anyone know what the screw in the last picture is for?
/ wheel loader lift high speed only #12
The black hex adjustment at the bottom of the valve must be for the pressure relief.
Possibly the valve could be made to meter smoothly by machining just the right place on the spool. It's a matter of the grooves on the spool lining up with the ports in the valve casting at just the right place. It could easily ruin the valve if not done correctly though.
/ wheel loader lift high speed only #13
Hi.
/MaxPax
In all open-center hydraulic systems, there is a check valve that prevents loader drop when the valve is partially opened. There is no check valve when lowering. So, when lowering you gently crack the valve, and oil is allowed to slowly seep out and loader movement is easy to control.
When lifting, there is already residual pressure in the lines and cylinders from holding the weight of the loader. Since it is an open center system, the pump circuit has essentially 0 psi. Without the check valve, as soon as you open a port the loader would drop until you continue to open the valve and force the oil flow from the pump to build pressure and lift the loader. Don't bother reversing the lines as it won't work correctly without that check valve.
Essentially when feathering the valve, you are trying to get the pump pressure to match the residual pressure in the loader, at which point it will start to move. That point on the loader valve is different depending on where the loader is in its travel, and how much weight you have in it. Some valves make it easier to control than others, but all open center systems are subject to this kind of limitation. This is a large part of the reason why closed center systems are used on larger machines. You can apply full pressure very slowly with closed center systems pretty easily. It's a hard thing to do on open center setups.
Ensure you don't have any binding or worn linkages, as that will make it more difficult - but you won't ever get this problem to go away completely with an open center hydraulic system.
Wow thanks for the informative answers!
So, could it be rebuilt to a closed center system easily? Like changing the directional valves etc. or would it be a too big project to be justified on a $6000 machine?
/ wheel loader lift high speed only #15
Nope. Closed center pumps are a completely different setup. Variable displacement, but constant pressure. More costly, which is why they aren't used on smaller machines. They are nice to use though.
Best thing to do is ensure the linkages are clean, lubricated, and tight. There's also a possibility that the controls don't allow enough of a "throw", which would make it more difficult to find that middle ground. Some modification in the linkage adjustment might help that, but I doubt it's worth the hassle. Operationally, when I need to feather something gently off the tip of a fork or the bucket, I will use the curl function instead of up/down. Generally it's easier to feather.
Ok thanks a bunch. Guess my machine have a gear pump then and a closed-center usually have a piston pump with swash plate and such.
Trying around with it today I think I can live with this and just learn to handle the levers.
/ wheel loader lift high speed only #17
maxpax
You could install an adjustable flow control valve in boom hose circuit. I did just yrs back that on a Kubota frt end loader for handling large rd bales.
/ wheel loader lift high speed only #18
I also did that on a homemade loader on a garden tractor. Made a big difference in how much control I had of the machine.
Thanks for that tip, I think I will do that. Seems simple enough.
Update on this old thread then.
I acquired a brand new valve pack, it had been sitting on a shelf for about ten years but very high quality (nimco) and very cheap b/c the owner wanted to get rid of it.
The connections on the bulky chinese pack is M27/2 thread, not very common so I cut and welded 1/2" BSP's, put it together an violà!
It's fethering perfectly now! Super precision, and since the new pack had three sections I put 2 new hoses in with a couple of 6/2-valves and put a cylinder on the attachment mechanism so now I jave 3rd & 4th function plus hydraulic tool change without having to go out of the machine (if no extra functions are used anyway)
So satisfied with this. Happy!!
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
John Deere Hood Guard (A63116)
John Deere Hood...
GRAVITY WAGON ON 5TH WHEEL GEAR (A63745)
GRAVITY WAGON ON...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59910)
2021 UTILITY VS2DX...
TAYLOR CARDBOARD BALER (A63745)
TAYLOR CARDBOARD...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59910)
2019 INTERNATIONAL...
