Dirt Moving Rops lights
/ Rops lights #1
Monster diesel
2011 kubota dx 2120
New 2017 BX23S installed four led lights now trying to figure what to do with excess wires and were to install switch IMG_0620.JPG
/ Rops lights #2
well I will say I don't think you will have and issue with overloading the wiring. on all of the LEDs I have installed on my tractors I have always tied into existing light switch with LED draw being so much less than Conventional lights I have never had an Issue with it.
/ Rops lights #3
G'day Mate and welcome to TBN from Downunder.
You may be able to simply access a pre-existing wiring connection at the rear of your tractor. On my 4105, it's a 'folded back & capped' 2 line wire. It's there IOT hook up front/rear lights (a factory option) and is already wired to the four-position main light switch = Off/Hazard/Hazard&Headlight/Hazard&Headlight&Worklights.
Ask at your Dealership if a connection like this is already there or perhaps another Member knows of this and can chime in.
/ Rops lights #4
New 2017 BX23S installed four led lights now trying to figure what to do with excess wires and were to install switchView attachment 516604
In my case, I used zip ties attached to small flat magnets and ran the wire down the inward face of the ROPS. I left a small loop at the hinge to allow the ROPS to fold down. I used a magnet to attach the switch as well and hooked it up to the work light wiring circuit in the harness under the right fender. I also wired a disconnect plug so the lights and wiring can be easily removed when working in the woods.
/ Rops lights
Nice job. I did similar on wiring but cut off excess and made a switch box but definitely not removable as yours
1997 GMC GMT-400 SINGLE CAB TRUCK (A62130)
1997 GMC GMT-400...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2013 KUBOTA RTV900 XT (A62130)
2013 KUBOTA RTV900...
Utility Cart (A59231)
