Looking for a three spool 6gpm DCV with one spool "float"
/ Looking for a three spool 6gpm DCV with one spool "float" #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
It seems they are not that common.
Larger flow rate units are more available, but size and sensitivity are important to this application.
I've got a RFQ in to Bucher. Are there suggestions for other vendors?
/ Looking for a three spool 6gpm DCV with one spool "float" #2
Possibly try Parker, Eaton, Danfoss, Hydac, Brand & Prince. They all make bankable valves but Not sure if any of these would have anything that small or not. The float option is probably the feature that will present the biggest challenge in the low flow rate.
Yes, All those brand names are familiar. The size is apparently the difficulty. A two spool valve off an old Bolen's HT might be an option. I would miss the third spool ...eventually ;-)
/ Looking for a three spool 6gpm DCV with one spool "float" #4
I got mine from Bailey's, 3 spool with one float. I don't know what DCV means though.
DCV Directional Control Valve
I've looked at Bailey's, What was the flow rating for the valve you choose?
/ Looking for a three spool 6gpm DCV with one spool "float" #6
10 gpm, 6th one down in this chart, SKU #220959: Shopping
/ Looking for a three spool 6gpm DCV with one spool "float" #7
