   / Harbor Freight Tools that don't suck #7,651
IMG_0717.JPGFound one at tractor supply Caldwell Tx. One left $8.49.
   / Harbor Freight Tools that don't suck #7,652
View attachment 516512Found one at tractor supply Caldwell Tx. One left $8.49.
You did good! That may be the last one left in the wild anywhere.
I used mine this morning to clamp some plywood to the benchtop so I could cut an irregular shape in the part of the plywood out beyond the bench. The clamp made it much easier.
This is a very handy tool.
   / Harbor Freight Tools that don't suck #7,653
At Tractor Supply bins I also saw a vice grips with a break over bar attach. Has anyone used one of these.
   / Harbor Freight Tools that don't suck #7,654
This is a very hand tool.
Theres a few more left at my TSC.. $6.99 clearance price. At least there were yesterday..
   / Harbor Freight Tools that don't suck #7,655
   / Harbor Freight Tools that don't suck #7,656
Dunno, but at least half the cost went into that hydro dip..
   / Harbor Freight Tools that don't suck #7,657
You could make one of those cheater bar vicegrips by welding some conduit on the adjusting screw. Be a good idea to stitch up the seam where it threads in as that will be the area that fails when you put a couple pounds of force on it. Won't look as flash as the whizz-bang graphics on the TS one though.
   / Harbor Freight Tools that don't suck #7,659
Vice grips with one side of the hand grip continuing out another 18(?) inches?
I saw those at TSC, couldn't imagine what I would use one for. Anybody know what those are used for?
Also I expect 18 inches of leverage on a cheap tool would only destroy it.
Actually, I have 2 of those- a smaller pair in bare metal- which came with both the regular adjusting screw, and the one with the cheater bar on it, and the other is [against my better judgement] one of the XL-sized "camo" ones.
They were both on clearance at different times and also under $10 at most, which is kind of my threshold for their "cheap" tools.
But I have to say, they are actually pretty sturdy, and I use them for what everyone else on here would- turning shizzat that doesn't want to turn.
I also have a bunch of their other "irwin vise grips knock-offs"- the right-angled ones, some with a big old round set of jaws- but I'm waiting for those pipe clamps ones to get marked down- hopefully concurrent with a 10% of coupon.
   / Harbor Freight Tools that don't suck #7,660
... I use them for what everyone else on here would- turning shizzat that doesn't want to turn.
Heck the year I paid for Inside Track, I bought two of HF's aluminum 24 inch pipe wrenches for that. Then a 36 inch. Its a monster. HF's ITC had them at reasonable prices. With cheater pipes on the handles of these tools they will either turn or destroy whatever is fighting back. :D
Actually I broke the last four inches off the handle of the first 24" aluminum pipe wrench that way. But with a big pipe extending it, that doesn't make any difference. HF's later revision of the 24 inch has a beefier handle and I haven't been able to hurt that one.
Hundred year old rusty plumbing here, 1.5" size, required these big pipe wrenches to get anything apart.
JOHN DEERE 750 (A58216)
JOHN DEERE 750...
2007 Toyota Camry Sedan (A56859)
2007 Toyota Camry...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
