Hydraulic hose protection?
/ Hydraulic hose protection? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I have numerous hydraulic hoses running all over my TN 70A. I would love to "protect" them from wear and tear such as rubbing against metal edges, sticks, and other stuff that wants to wear the hoses out early. Any ideas of what I can wrap around these hoses to protect them that will look good doing it? Something that will look professional, with a clean appearance. Any commercial products?
Bob
/ Hydraulic hose protection? #2
Go to www.DiscountHydraulicHose.com and choose "sleeving" from their menu. You probably want the nylon abrasion sleeving. That is what you see on most tractors.
Thanks. Looks like I have to remove the hoses to use the nylon. They also have a plastic coil product in their catalog pdf (not online) that looks like it does not require removing the hoses.
Bob
/ Hydraulic hose protection? #4
Bob
I have found Bob that most things that are worthwhile don't come easily or without some labor. We used some of the anti-abrasion sleeve on the hydraulic hoses for our grapple.
Yes, "no pain, no gain" :D
Bob
/ Hydraulic hose protection? #6
I use radiator hose line.. slit it lengthwise.. tuff.. but not pretty.
I like tough.
Bob
/ Hydraulic hose protection? #8
Yep, one hose on my hoe wasn't protected and rubbing on the hole in the dipper, and I just slit some small heater hose. Hose sheath works well for elec cables, air shock tubing, lotsa things ... cheap and easy to use. Radiator hose works well for a bundle of hoses ...
/ Hydraulic hose protection? #9
Another inexpensive option is split loom. You won't have to remove the hoses so it's easy to install but it isn't the strongest material. Here is a link.
Looks good, easy, cheap and will take any wear and then show it.
Bob
/ Hydraulic hose protection? #11
i use condemned fire hose to cover my hydraulic lines. i am able to get it from time to time through where i work. works great and the price is excellant.
/ Hydraulic hose protection? #12
You can also use a piece of rubber mudflap - wrap it around the hose(s) and zip tie it in place. Sometimes you can find them laying on the side of the road - quick, easy, and FREE :)
Ken, I would guess with the miles you drive you see lot's of mud flaps on the road. FREE mud flaps! :)
Lot of great ideas suggested here to protect the hoses.
Bob
/ Hydraulic hose protection? #14
There's a plastic version of the steel type shown in the Disc HYD. I'm not sure where to get it in US, but we use it offshore and it's called spiral wrap. Really easy to work with and no hose removal.
You live in LA? Where do you get it if not in the USA? What is DISC HYD?
Bob
/ Hydraulic hose protection? #16
If you are looking for tuff and ugly.. I'm sure old fire hose fits the qualifications.
But you will have to take the hose off.. but then.. yuo will with nylon sheathing too.
Soundguy
Bob
/ Hydraulic hose protection? #17
Steel spring guards and plastic spring guards are probably the best way to protect hydraulic hoses without having to remove them from your assembly. But sleeving and flat wraps are good options if you want protection and something that looks good. You can find the differences between different kinds of hydraulic hose protection here. It's a short article but explains the differences between types of hydraulic hose protection.
/ Hydraulic hose protection? #18
old inner tube or radiator hose you can pick up at auto repair garages works well.
/ Hydraulic hose protection? #19
I went to the House of Hose, Spokane, WA and they have extreme duty spiral wound nylon hose protectors. Looks a lot like the old spiral wound telephone chord running from the phone to the handset. Its kind of a PITA to "unwind" and slip over the hydraulic hoses. The good thing - once its installed you are done. I ran over a discarded one foot long chunk with my lawn mower - barely put a nick in the stuff. I used 32 feet to protect all the exposed hoses on the tractor.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
