FIMCO sprayer check valve
/ FIMCO sprayer check valve #1
TheMan419
Indiana
New Holland Boomer 24
I have a 40 Gal Fimco 3 point hitch sprayer. It won't hold prime. Ran 3 tanks of round up through it. Went to clean it and pump runs but won't build pressure.
Screen on intake line is clean. Pulled intake line and it is clean.
According to the internet tubes the check valve is next most likely culprit. Looks easy enough to change out. However I cannot find one locally. Anyone know if it is something that just needs cleaned well or if I can tell from looking at it if it is out of tolerance and actually needs to be replaced?
I am at work at the moment and this happened last night. So I'll pull it when I get home to look at it.
Thanks for any advice.....
/ FIMCO sprayer check valve #2
How old is your pump? When mine went out after one year, I called them up and they sent me a new pump for free.
Duh did not think of that. Less than a year old.
/ FIMCO sprayer check valve #4
I had a similar experience with my Fimco 25 gallon ATV sprayer ... :thumbsup:
So just got off the phone with FIMCO customer support. First thing the guy asked me was what I was spraying. Generic Roundup with a surfacant. He said that is a known problem for their check valve.
He recommends pulling check valve and soaking in warm soapy water for an hour and then giving a good scrub with a tooth brush.
Further recommendation is to cease using surfactant in the roundup or use dish soap as the surfactant. Given there is no material cost difference between a product with surfactant included I'd like to keep using it. Is dish soap a good alternative and if so how much to add to a 40 gallon tank? Dish soap is not that expensive and if it keeps me from having to soak the check valve and works as a good surfactant then I would likely just do that.
/ FIMCO sprayer check valve #6
I never liked using dish soap because it would foam up real bad making it difficult to fully fill subsequent tanks.
/ FIMCO sprayer check valve #7
If you have a PTO pump, most won't spray if they rotate and are mounted upside down. Just a thought.
Yeah I was getting enough foaming with just the chemical on subsequent tanks.
Pump is 12 volt and hooks up to the battery with alligator clips. Pump starts humming when hooked up. Just no fluid pulled from tank and pushed out boom or spot sprayer.
So here is the update. FIMCO said clean the check valve. Did that. No help. So they are sending me a new one.
However they say that since I was using surfactant this is the only time they will replace it. The thing that upsets me is that the manual does not say anything about surfractant being an issue.
New check valve should arrive tomorrow.
/ FIMCO sprayer check valve #10
You can get an anti foam agent from a farm store.
Using dish soap as a surfactant--wetting agent--can create it's own problems by changing the dynamics of the chemical. I killed some larch trees once with a chemical approved for them--their bugs, actually--by adding dishwashing soap. Recently I saw a warning on a chemical label advising against the use of the dishwashing liquid. I no longer add it but buy generic roundup with the surfactant already added. It works fine. Just my two cents here.
You can get an anti foam agent from a farm store. Using dish soap as a surfactant--wetting agent--can create it's own problems by changing the dynamics of the chemical. I killed some larch trees once with a chemical approved for them--their bugs, actually--by adding dishwashing soap. Recently I saw a warning on a chemical label advising against the use of the dishwashing liquid. I no longer add it but buy generic roundup with the surfactant already added. It works fine. Just my two cents here.
That is the problem. I used generic w surfactant added. Fimco says this is what messed up check valve. Have to use it without or next check valve will also cease working.
/ FIMCO sprayer check valve #12
Is the brand on the pump FIMCO, or another brand?
The only electric pump I have extensive experience with is Nothern Tool's Northstar brand. I've had no issues with using the generic roundup with surfactant. I flush it well with clean water after every use.
To eliminate foaming while filling up, you need to fill from the bottom. Probably not an easy option with an electric sprayer, but you may be able to install a bulkhead fitting somewhere in the bottom. On my 60 gallon sprayer with a PTO pump and the recirculating system I replaced the fitting connecting the return line to the tank with a tee and with a short piece of hose I added a garden hose adapter and valve to it. I hook the garden hose directly to that to fill now, and there's no foaming. Sticking a good bit of hose under the water level will help also, but then you'll have the chemical on the hose.
Is the brand on the pump FIMCO, or another brand? The only electric pump I have extensive experience with is Nothern Tool's Northstar brand. I've had no issues with using the generic roundup with surfactant. I flush it well with clean water after every use. To eliminate foaming while filling up, you need to fill from the bottom. Probably not an easy option with an electric sprayer, but you may be able to install a bulkhead fitting somewhere in the bottom. On my 60 gallon sprayer with a PTO pump and the recirculating system I replaced the fitting connecting the return line to the tank with a tee and with a short piece of hose I added a garden hose adapter and valve to it. I hook the garden hose directly to that to fill now, and there's no foaming. Sticking a good bit of hose under the water level will help also, but then you'll have the chemical on the hose.
It is fimco. It is an electric pump. Yes jamming the hose under the surface helps keep the foam down.
/ FIMCO sprayer check valve #14
thats weird. i have the same sprayer and ive had it for 10 years. i always use surfactant. i also always use a neutralizer after im thru spraying. I rinse out tank 2-3 times.
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
