Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,321
I have some places like this where I can just squeeze thru with my L3010.
But the new to me M5640 is almost 2' wider so there are some rocks to be moved . Tried the Frost Bite grapple out on Rock Plucking. Works very good. Nothing but the rock you are working comes up with a narrow open grapple. Here are a couple examples of nice VT rocks.
gg
/ Grappling fun - A Picture Thread.... #1,323
That is asking a lot :D
Try the chain thing - cheap enough. Might want some cross chains. Maybe that is what you meant by a basket. I am just guessing but I think something with spaced out teeth would be better than a smooth plate. Teeth seem to catch on irregular small rocks pretty well. Seems like the plate would work if you could get under them w/o just pushing them forward or on roundish rocks. Then again maybe it would be fine. Duh !
gg
Hi GG,
Those side teeth on your bucket look to really enhance your bucket grapple, did you fab them or are the a standard add-on?
Which of your orange tractors is that- I'm not good enough to be able to tell from that angle [or prolly any other where the model # isn;t frotn and ctr... :ashamed:]
Thanks!
PA.
/ Grappling fun - A Picture Thread.... #1,325
Had three stump root balls left after burning the brush pile.
Grappled them in the 6' wide dual lid Monster Grapple and deposited them in the Brush Ravine. :thumbsup:
/ Grappling fun - A Picture Thread.... #1,326
Then I put the boom in float and spread out the ashes.
/ Grappling fun - A Picture Thread.... #1,327
X, you kill me with your pics. I know it's you before I check the signature on the post.
/ Grappling fun - A Picture Thread.... #1,328
Hi GG,
Thanks!
PA.
That is my L3010 - 30 hp. You are right - the tooth bar made a huge difference using the bucket grapple for both logs and rocks. It is a WR Long tooth bar. It is a very capable grapple.
/ Grappling fun - A Picture Thread.... #1,329
Toothbars can be great especially for digging but be aware that they make things a bit difficult when it comes to common tasks like scraping up sand or dirt piles off asphalt or back dragging. So long as they can be easily removed toothbars are a nice addition especially when part of a bucket grapple combo. However, if you add a ssqa grapple to your toolbox they have little purpose and almost no benefits over just switching between grapple and plain bucket. Also, compare toothbar to Ratchet Rake too as another way to occasionally modify a standard bucket. Toothbar better for digging and RR better for clearing brush and preparing soil for seed.
/ Grappling fun - A Picture Thread.... #1,330
I agree that a tooth bar makes it hard to clean loose material off down to a hard surface like sand on asphalt but back dragging is not a problem. Just use the wear plate on the heal of the bucket.
I also agree that having a separate grapple with a SSQA makes the most sense but in the case of my L3010 there is no SSQA. I would say that the bucket grapple and tooth bar are a great way to go. I do a ton of work with that combo and pound for pound there is little it won't do.
gg
/ Grappling fun - A Picture Thread.... #1,332
Great pics deleted for brevity...
Hi GG,
Thanks, but I actually recognized the toothbar as a WR Long, it's those side crenulations I was asking about on the lateral edges of your bucket.
Thanks,
PA
/ Grappling fun - A Picture Thread.... #1,333
gg
I also don't have a QA bucket, so instead I lust for a bucket grapple like Gordo's, and I already have a PTB from Harry, so all I'd need [in addition to that little petty cash item- the 3rd fcn or other remote hydraulic circuit] is to weld on some of them side teeth he has on his bucket, and I'd be good to go!
[In other words, ignore my previous crenulations question- your pictures #1 and #5 above answered it- and it also looks to be a great way to stiffen your bucket against the counter-torque from closing the grapple too.]
Thanks again,
PA
/ Grappling fun - A Picture Thread.... #1,334
Hello,
My friend is going to order grapple similar to your in picture, but black and without these tiny nails. Will this model fits for forest works?
Thing is that he's going to order it from company we know nothing about, but price seems relatively good. Any ideas or notices regarding the quality?
Grapple bucket KR-D | Padagas
Thanks
/ Grappling fun - A Picture Thread.... #1,335
Hello,
Thanks
That's a skidsteer bucket. 450kg is way too heavy for a compact utility tractor.
/ Grappling fun - A Picture Thread.... #1,340
What would you recommend instead? (My Tractor John Deere T 6050)
I don't know of a John Deere T6050. New Holland makes a T6050 which is a utility tractor.
What is the weight of the tractor, how many horsepower and what is the loader lift capacity?
2018 CATERPILLAR 249D SKID STEER (A62129)
2018 CATERPILLAR...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A61165)
2012 Freightliner...
STACK OF FABRICATED BUMPER SHEETS (A62130)
STACK OF...
New/Unused LandhonorQuick Attach Backhoe (A61166)
New/Unused...
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
