Backhoe for 2538
/ Backhoe for 2538 #1
aerojunkie
Kannapolis, NC
Mahindra 2538
How do you guys like the backhoe for the 2538 tractor? I have had several times in the last few weeks I could have used one if I had it, so I'm in the market for one. I should have bought one with the tractor and then financed it, but on the good side there isnt much difference in price buying now through my dealer and I wont have any interest on it, he quoted me $7000 for it. I do like that it is almost as powerful as a backhoe for the 2555 spec wise. I figure with a backhoe, a ratchet rake, and a grapple there isnt much I cant get cleared or moved. So for $7000 do you get a good loader with good controls? I had a guy dig a water line recently with a small kubota tlb and was amazed at how precise he could dig and what he could do with only about a 22hp tractor.
/ Backhoe for 2538 #2
You will be surprised how much more your 2538 will be able to lift and maneuver with the 1200 lb backhoe in tow. The backhoe digs great and has managed to get out at least 20 stumps for me.
/ Backhoe for 2538
Thats true, would make for a heck of a ballast back there. I loaded my tires with the standard anti freeze/water solution but another 1200 it really would push the bucket along nicely. How hard is removing the backhoe and back to the 3pt? I havent found a video of the 2538 but of several other tractors, it they are basically the same should be a quick thing to do. How strong are the hydraulics on the hoe? I have read a few places where people have tested them by lifting the rear of the tractor with the arm fully extended similar to pushing down with the bucket. One last thing, what size bucket did you get? I was thinking a 12" should be sufficient for all around use and give a little clearance for digging down deeper, but never used a backhoe before.
/ Backhoe for 2538 #4
The backhoe only takes about 15 min to unload and a little longer to load back up. The key is to dump it on level ground. On the 2538 it is frame mounted so the 3 point is just left in the down position while the backhoe is hooked up and hangs just below the frame of the backhoe. I have seen stronger hydraulics on bigger machines. It isn't possible to shift the machine to one side just using the bucket. The stabilizer are only set up to get the rear of the machine a little off the ground. I have a 12" bucket and at times have wished and I had smaller and at other times wish I had a bigger one. Overall the 12" will be sufficient.
/ Backhoe for 2538
Well Im back looking at the backhoe again. I thought about just getting a bigger tractor instead but I have found some places over the past couple weeks that a larger tractor would be rather tough to get into. My main thing is I want to get stumps dug out in the woods behind my house Im trying to clean up. its never been cleaned just left to grow and most of the trees are just a little of everything. I have a lot of 8" and less trees I want gone and bought a stump bucket to try but seems like that is a lot of wear and tear on the loader with a chance of damage thrown in there. I figure a backhoe and a grapple can take on pretty much anything I want to do for cleanup given enough time. I would also like to dig a small pond out, nothing major maybe 1000-1200 sq ft and may take a while but I figure it should be able to do it. So you think it would be up to all that? Whats the biggest stump you have dug up? Just trying to get an idea of the limits on this thing.
/ Backhoe for 2538 #6
You can dig big *** stumps that are old. I have a double 14-16" green one that I still can't get out. I have it dug out 6' deep the whole way around. The backhoe on the 2538 is amazing but doesn't have the breakout force of a standard backhoe.
/ Backhoe for 2538
Wow, sounds like it should do a lot more than I need then. The biggest I am planning to remove it probably in the 10" range. I would like to just cut down what I want gone then go back and remove the stumps when there is more room. I keep watching the youtube videos of a kubota tlb like a bx25 and amazed at what a small machine can do given the time and this one should do a good bit more. One thing I can figure out is the one cylinder for the dipper, most of the others have 2 shorter cylinders and not one long one. With it extended that long do you thing there is a chance of it bending something?
/ Backhoe for 2538 #8
i have the 2555 hst with 65B hoe. at first i was a bit disappointed with the power of the dipper but i used it for about 4 hours today and after getting used to it and using the float feature it digs real nice. glad i got it.
/ Backhoe for 2538
What is the float on a backhoe and is it on the backhoe for the 2538?
/ Backhoe for 2538 #10
Biggest stump I pulled out with my 2538 is actually more weight then it can lift... dug around oak stump 4-6' below grade, bucket teeth cut / ripped roots. Was able to pull / roll the stump out and drag down to where I need to cut in half to load onto my trailer to haul away. Left quite the bomb crater .
/ Backhoe for 2538 #11
Heck, if your trees are that small, you may be able to simply push 'em over with the FEL bucket. I've done this to quite a few trees (and there are a few topics on that kind of stuff), then hooked up the chains to remove the stump. Very large ones, I've been using the backhoe (I have a 2540), but I'm getting tired of that, so I'm using a Woodland Mills stump grinder to turn them to chips.
/ Backhoe for 2538 #12
it is part of the backhoe itself and not the tractor. You will have to ask the dealer for whatever model fits the 2538. Float just allow the boom to move in automatically. Pell's Massey Ferguson Compact Backhoe’s - YouTube
the video doesnt show how it works for digging but it shows the concept. it works real nice when digging.
/ Backhoe for 2538 #13
That was a good video.
I always figure float is whenever something is that is under float, it's level is under the force of gravity alone.
DRIVEWAY ENTRY GATES (A60736)
DRIVEWAY ENTRY...
2025 Poly Fuel Tank with Electric Pump (A61568)
2025 Poly Fuel...
SP36 VIBRATORY TRECH GRADER (A60736)
SP36 VIBRATORY...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
