Need a mask for cutting grass
/ Need a mask for cutting grass #1
murph1
Ohio
MF-135 DK-40se Ventrac 4500
Hey Guy's. I have COPD and need a mask for grass cutting be need to be careful about air flow. Any Idea"s
Thanks for any and all responses.
/ Need a mask for cutting grass #2
What about a spay painters mask. Can be had with one or two filters and some have pre filter to extend the life of the filter canister. You could get one a an automotive paint supplier. Might even be able to try one on to check for comfort. Rick
/ Need a mask for cutting grass #3
I use some basic 3m facemasks I got from the hardware store: Amazon.com Page Not Found
They work noticeably better than similar looking ones from Harbor Freight- better fit, better filtering, less breathing restriction, last longer. These are less of a breathing restriction than my painters mask with replaceable cartridges.
3m make similar models with one way valves in them for easier breathing out.
/ Need a mask for cutting grass #4
I use 3m masks with one way valves in them for easier breathing out. They are a little more expensive but well worth it to me. Definitely makes breathing out more comfortable and doesn't cause my glasses to fog.
/ Need a mask for cutting grass #6
I'm allergic to grass pollen so I wear a mask when mowing. I use the 3M 8233 masks with the exhale valve. They're rated N100. They work well for me, almost no sniffing after mowing.
/ Need a mask for cutting grass #8
clean the face up. no hair, so mask fits better against skin.
there are full face masks, with a fan inside, that pushes air to you. but these masks are rather expensive, and might work with facial hair. the blower might help keep you cooler under the mask.
pending on how small you need to get down to, to filter and start getting into microns, and in that start buying cannisters, that fit a given face mask. something that just covers nose and mouth, but not the eyes can work. you sweet but work.
/ Need a mask for cutting grass #10
The masks with the plastic valve in the front or the only ones I buy. We used them in a factory I worked in where some of the powders would cause a nose bleed after four or five breaths. They worked great.
RSKY
/ Need a mask for cutting grass #11
I have asthma and need a mask around chemicals, working under the house, mowing lawn, etc. This works well and does not get in the way: Half Mask Respirator Size Small/Medium - - Amazon.com. Yes, it also fits under most welding helmets. Various manufacturers have their name on it and various prices also.
/ Need a mask for cutting grass #12
Moldex 24 N95 Nuisance O/V (Bag of 1) | PK Safety
The plastic mesh support keeps the mask sturdy and conforming to your face. Initially expensive but they last so long that you end up throwing it away not because of wear but because they get so filthy you can't stand putting it on your face anymore. Come to think of it - I'm going to put one in the washing machine - it might hold up.
/ Need a mask for cutting grass #13
I find a handkerchief to be reliable. Many of the masks I've tried, even more expensive ones, the rubber bands stretch/break rather quickly. I also have a reusable one, but the handkerchief is a more snug fit.
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
John Deere 608C 6 Row Corn Head (A64119)
John Deere 608C 6...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
