FEL Issue
/ FEL Issue #1
alexsbuddy
Gold Member
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
The 3109 FEL on my XG3037 is raising very, very slowly and the bucket seems to develop some slack or play when left in position after a few minutes. The FEL also seems to be straining to reach maximum height. This all started suddenly today for no apparent reason. Tractor has 160 hrs and was serviced completely at 100 hrs. Any ideas on what the problem any be? Any assistance would be truly appreciated.
/ FEL Issue #2
Check to make sure all of your FEL quick connects are seated correctly. Take them off an put them back on.. It is worth a try, and has fixed several with this problem.
/ FEL Issue
Reseated all of the quick connectors and no improvement. One other detail I forgot to mention in my original post...there seems to be some vibration when I am lifting the FEL. I can feel it through the seat, steering wheel via my hands, and floorboard via my feet. This has me really baffled.....have never over exerted the FEL and no impacts.
/ FEL Issue #4
If for sure the pump is making the correct flow rate, then the next thing is that one of the Quick Connects is bad.. Yes there is such a thing where the quick connect valve oscillates and does not allow the proper flow. This is rare but I have read about it here. I would like to see a flow test on the pump. and if that passes I would swap around the QC from the lift to the curl function. I guess you could have something stuck in the valve or somewhere. It is going to take some testing/unhooking and flow testing in a clean bucket. to find this.
/ FEL Issue
Thanks, James. I have a hydraulic pressure test gauge/hose and fittings ordered so hopefully will be able to do some testing this week. Will report back on my findings.
/ FEL Issue #6
I wonder what the chances are that the PRV (Pressure Relief Valve) is defective? Here is a hypothetical scenario. As the flow comes from the pump and the loader valve switches the flow to start filling the lift cylinders, the pressure starts to increase as the fluid runs into the piston inside the cylinder. As the pressure is increasing a weak spring in the PRV might cause a "shudder" and slow filling of the cylinders as some of the fluid is flowing around the weakened spring and shims. Just another idea, but it would be an easy one to fix. Keep us informed on what you find. I would like to know if any of my "BS" scenarios are the real culprit. :)
On any scientific method repair procedure, you must first analyze, then form a hypothesis, and then prove or disprove that hypothesis. Then repair or replace the suspected component and retest.
Easy for me to say right?:) Good luck with it.
/ FEL Issue #7
When is the last time you greased the loader?
/ FEL Issue
There are no lube zerks on the 3109 FEL, but I did lube all of the pivot pins. No change. I also tried adjusting the pressure relief valve on the loader valve body....tried increasing and decreasing the pressure with no real change either way. I will be able to do some pressure testing once my pressure gauge/fittings arrive and this might help to isolate the problem. Will keep you posted.
/ FEL Issue #9
Any chance you can take a video and post?
/ FEL Issue
A video is a great idea....I will do this tomorrow after work and will study up on posting it to this forum or via You Tube with a link.
On another note..man, I feel stupid. I had earlier written that the 3109 did not have zerks for lubing. I knew better than to look for these in poor lighting. Today, I took another look and the zerks are actually recessed in the pivot pins so that they are flush. Will give these a good lube tomorrow as well.
/ FEL Issue
Turns out that the eye bolt which secures the suction line to the main suction pump had come loose and causing a loss of pressure. Dealer fixed on the spot without even having to unload the tractor. He recommended checking this occassionally. All is good!
/ FEL Issue #12
<snip>
From post #4. well it looks like the pump was NOT making the correct flow rate because it was sucking air!. Oh well glad you get it fixed and easy.:thumbsup:
LD1, you should have thought of that broken suction hose...happened to you too!:)
/ FEL Issue
You were spot on!
/ FEL Issue #14
Yea, air does some funny things.
But you should have though of that too because you bought the hose to fix the suction issue;)....you just jumped ship to the "other" orange before yours became an issue.
/ FEL Issue #15
That is what you call "being smart":laughing:
/ FEL Issue
Here is a picture of the eye bolt/suction line/main suction pump (right side). You can see the bolt head on top...this is what had come loose and allowed air in and fluid out. You can see the fluid residue. 20170706_181416.jpg
/ FEL Issue #17
Here is a picture of the eye bolt/suction line/main suction pump (right side). You can see the bolt head on top...this is what had come loose and allowed air in and fluid out. You can see the fluid residue.View attachment 514502
Yeah, the Kubota that I used to own has a rubber hydraulic suction hose bent into and L shape that was notorious for eventually splitting and leaking air. I bought a replacement hose for the time when it would start to leak because they all seemed to do it over time. I sold the hose to LD1 when I swapped off the tractor and I believed his started to leak and he used the new hose I sold him. :)
/ FEL Issue #18
Never leaked. Just sucked air and made hydraulics jumpy. So got the hose from you and replaced.
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
