Post hole digger: PTO vs. hyd. SSQA
/ Post hole digger: PTO vs. hyd. SSQA #21
I rebuild a 3pt PHD to fit a QH & mount 200lbs over the gearbox. Ran good behind my L3200. With a 9" & 12" auger. 9" sucked until I got good teeth. The huge carbide frost teeth it came with couldn't bite into our clay. PHD ran off with the tractor.
Upgraded to a L4060 & got a 3rd function on it. Got the small Danhuser PHD (6-12gpm I think) with a 2" hex & 12" auger. Offset mount makes for good, but not great visibility. Visibility & reverse are nice compared to the 3pt, but it has a lot less power. I never got the 3pt PHD stuck (got close a few times) so reverse is just for flinging dirt off.
In the 30ish holes I've dug so far the visibility & ease of mounting have kept pace or exceeded with what my 3pt unit would have done. Hard ground on a big project might have missing the straight mechanical power of the 3pt. Don't know what 10gpm * 2500psi equals, but it's less than the 25 PTO HP my L3200 had (not that I got there at slow PHD RPMs).
With the SSQA hitching is a breeze. Blew out my back twice hitching up the 3pt unit (once after the QH conversion). Never blew a sheer pin on the 3pt. Stall the hydraulic unit all the time, but the relief valve just takes care of that.
/ Post hole digger: PTO vs. hyd. SSQA #22
Having just spent 2 days running my landpride 3-pt PTO PHD, if I had it to do all over again, buying a front mount hydraulic unit is a no-brainer. Without down pressure, a 3-pt unit is almost worthless if you have any rocks IMO. I would also buy a hex drive, so you can swap augers easily.
/ Post hole digger: PTO vs. hyd. SSQA #23
If, for some reason, you ever wanted to auger a post hole at an angle, you could do it with the hydraulic unit.
Also, I once saw a manufacturer online who offered a hydraulic auger drive unit with a cement mixer attachment...I haven't been able to find that one again, though.
I bought a Belltec NC150, but there are several manufacturers of these low-flow units with comparable capabilities.
/ Post hole digger: PTO vs. hyd. SSQA #24
Seen those around. Got a 3pt mixer with a busted chain a year or 2 ago. Thought about welding on a 2" hex mount to the drum & scrapping the rest rather than fixing it.
/ Post hole digger: PTO vs. hyd. SSQA #25
I had asked the group about the mixer/auger setup a few weeks ago but no one had used one. This is the model I was eyeing:
Eterra Skid Steer Cement Mixer Attachment | Skid Steer Solutions
Still looks like a good idea to me. I have some holes to auger soon and am going back and forth between the Everything Attachments PTO auger and a skid steer type hydraulic unit. I just don't want to spend three times as much when I'm only augering a few dozen holes a year at most.
/ Post hole digger: PTO vs. hyd. SSQA #28
...and having a brave 200-lb buddy stand on the lower link arms with a 3pt auger helps...
YIKES. No thanks! I'm in the hydraulic SSQA camp. I have the Danuser EP6 with the offset mount. It works well but I wish I'd sprung for the EP10. I really don't care how fast it spins.
/ Post hole digger: PTO vs. hyd. SSQA #29
That would be the EP6. Its spec'd at 1500 ft-lb, while the EP10 is 1900 ft-lb. (@3000 psi).
/ Post hole digger: PTO vs. hyd. SSQA #30
So on an M7060 with the 6speed (F12/R12) the hydraulic pump capacity is listed at 16.2 GPM. How much does the hydrostatic power steering take away from this? OR, does Kubota already spec the GPM taken from the steering after the fact, giving us the rating of 16.2 usable GPM?
If that's the case, I'd imagine the Danuser EP10 would be the better choice?
/ Post hole digger: PTO vs. hyd. SSQA #31
Tractordata usually breaks that out, but doesn't for your machine. My L4060 has 14gpm of flow about 5gpm of which is dedicated to steering. TractorData.com Kubota L4:cool: tractor information
I'm gonna guess your M7060 has around 10gpm of usable flow as well rather than 16.
/ Post hole digger: PTO vs. hyd. SSQA #32
Looks like TBN is breaking URLs again... www tractordata.com/farm-tractors/007/4/1/7417-kubota-l4060.html
/ Post hole digger: PTO vs. hyd. SSQA #33
Tractordata usually breaks that out, but doesn't for your machine. My L4060 has 14gpm of flow about 5gpm of which is dedicated to steering. TractorData.com Kubota L46 tractor information
Okay, with that being said, if you look at the same M7060, now with the 4 speed (8F8R), the listed hydraulic capacity is now 11.0 GPM. So, with your theory, this machine would have even LESS usable flow available...???? (less than 11 GPM?)
(the capacity is boosted to 16.2 on models equipped with the 6 speed 12F/12R)
to add, reading this article, they do mention having 16.2 GPM "implement" hydraulic flow.
2014 Kubota M7060 Open Station Review
maybe it does have all 16 gpm available...
they sure make it confusing...
/ Post hole digger: PTO vs. hyd. SSQA #34
Could you give us a list of the parts and a pic of yours?
This is mine.
First, get a used PTO PHD, then replace the driveshaft with an hyd motor. What you need is
a large-displacement motor to get the low-speed high-torque you want. I used a White
motor with 7 cubic inch displacement that can handle the 2500psi that most modern CUTs
put out. That way, you do not need a crossover relief valve.
You need to fabricate the motor-to-gearbox coupler. I hung mine from my backhoe and
used the curl circuit for hyd power.
Do a search on TBN to find several hyd PHD builds.
/ Post hole digger: PTO vs. hyd. SSQA #35
dfkrug -
Thank You
/ Post hole digger: PTO vs. hyd. SSQA #37
Okay, after confirming with my dealer, the M7060 with 6 speed, (12F/12R) actually does have 16.2 GPM available for implements. So it has been brought to my attention that the McMillen 1475 would even be a better fit, with an available 2377 Ft Lbs. :shocked:
/ Post hole digger: PTO vs. hyd. SSQA #38
Make sure you verify that in your service manual. I would have expected more like 12 or so for
implements, and the rest for steering.
Anyway, skidsteers generally offer more flow for implements vs. tractors, even without their
higher flow options. Worksaver offers 2 different hyd PHDs, one for CUTs, and one for SS's. I
have had the 714 for CUTs, and it worked fine. Way less $ vs. the Danuser or McMillen units.
/ Post hole digger: PTO vs. hyd. SSQA #39
I like that aussie Eterra unit. Everything about it - including the price - looks good. I know about 3pt PTO PH digger problems. I've got a good one of those with lots of augers and plenty of tractor to spin it with. But mounting up that 3pt digger and actually digging a hole in our soil with rocks and roots is a challenge.
Then the 3pt PH digger just sits there for years between jobs. If it also poured cement - like the Eterra unit - it would sure be more useful.
rScotty
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Stout Buckets HD72-3 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Bandit Wood Chipper (A62613)
Bandit Wood...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
