Using DR PTO trimmer on Cat 2 Tractor?
/ Using DR PTO trimmer on Cat 2 Tractor? #121
Hmmm, anything special that would need to be done to weld the ends?
Aaron Z
not really. fairly typical way to keep wire cable from unraveling. like taking a match to nylon rope. I think the preferred way is to just heat it with a OA torch. (least thats what i do) IE you dont need filler wire that a mig or stick welder would add.
Mind the mushroom on the end if you have to feed the line through a small hole or something, Its hard to tell what the tolerance on that string holder is.
/ Using DR PTO trimmer on Cat 2 Tractor? #122
So just heat it up with a torch till its cherry red?
Normally, the line has to be fed through, but removing one bolt on the bottom of the spindle will let you just set the line in (ie: the pieces the line goes through are just stacked and come apart if you pull the bolt).
Aaron Z
/ Using DR PTO trimmer on Cat 2 Tractor? #123
So just heat it up with a torch till its cherry red? Aaron Z
Generally it has to be hotter than just red. orange or yellow, so that the metal starts to melt slightly and ball up on the end. (which is why its an OA torch and not propane) Its only 1/8" aircraft cable so it doesnt take much. You can put a slight mushroom on the end so you know the strands are welded together, then before it cools you can beat it back to nominal diam on a vise or something.
Just try a few times before to get a feel for it before you cut off the lenghts. I prefer to use a cut off wheel to cut the cable as opposed to some sort of jaw cutter.
/ Using DR PTO trimmer on Cat 2 Tractor? #124
I wonder if a Beaver blade could be used on the mower instead of the line head? I know it can be used on the Dr. trimmer mowers. That would certainly make for more aggressive cutting results, without need for aircraft cable and the potential problems broken pieces of cable might cause in the field around fence posts.
I put a call in to the factory store and waiting on a reply - probably tomorrow.....
/ Using DR PTO trimmer on Cat 2 Tractor? #125
Let us know what you find out ?
Scott
/ Using DR PTO trimmer on Cat 2 Tractor? #126
I looked into this attachment, but the reviews weren't too good.
I do have a DR trimmer, but it's one of th wheeled machines (not self propelled).
I am really curious how well TBNers (who actually buy one) like 'em...
/ Using DR PTO trimmer on Cat 2 Tractor? #127
A TIG torch would do it in a heartbeat
/ Using DR PTO trimmer on Cat 2 Tractor? #128
I picked up a new set of hoses (T rated so I can use propane down the road if need be) and a pair of flashback arrestors for my oxy-acetelene torch, set.
Will give the cable idea a shot.
Aaron Z
/ Using DR PTO trimmer on Cat 2 Tractor? #129
The Dr. factory store in VT told me they went from brackets to welds in a few places as the earliest version of the 3PT came to market. They said there is a new version of the string line holder that comes with the current machines being sold now, but the item is back-ordered currently. The new line holder is designed to keep the string in place better than the prior design. It is retro-fittable to machines built before it was available.
As far as attaching a Beaver blade with chainsaw chain attached, the 3PT Dr. mowers don't have the clutch and bail-bar that the walk behind and self-propelled units use, and without that and some sort of added bracket to keep the blade from cutting into fence posts there is currently no provision for the Beaver blade idea to be used at this time.
I suggested they make the necessary changes to upgrade the machine to it's full potential by adding a cable control similar to the mowers they make that tow behind an ATV or lawn tractor. This would allow for disengaging the blade and then they could add a bracket to keep the blade away from posts.
FWIW, another completely different approach that may work for many is the following: Cutthat.com | Sabre Samurai a front mounted bucket, small sized sickle bar mower controlled by a aux front hydraulic circuit. It might serve the additional uses of a grapple, or angle capable snow blade, etc.
I forgot to mention, the Samuri also allows 110 degree of adjustment to allow for cutting ditches, as well as hedges, vineyards and overhanging tree branches up to 1 1/2" in size. That gives it way more usage possibilities, IMHO, than a big 3PT driven single use machine. Note: I am in no way associated with either company, just expressing my personal views here.
Food for though to alternatives for different uses/needs. :confused3:
/ Using DR PTO trimmer on Cat 2 Tractor? #130
On ours the problem isn't keeping the line from coming off its that the line wears right off if you get too close to the ground or a rock.
Odd, the round guard on the PTO model (which is different than the guard on the self powered ones) should keep it from cutting into fenceposts.
Aaron Z
/ Using DR PTO trimmer on Cat 2 Tractor? #131
I'm just relaying what I was told by Dr. The guard might well already serve the purpose of keeping a Beaver blade from contacting the fence posts, I don't have a machine to determine that answer.:confused3:
From Dr.'s POV they need to factor in the constantly spinning blade into any such use. An individual could try the Beaver blade mounted with the correct aluminum ball on the bottom of the head assembly, just as it would be fit on one of the self-propelled walk behind trimmer/mowers, and see what the results were. Their method of stopping the Beaver blade would be to turn off the PTO and tractor before exiting the tractor station/cab.
I'd try it myself, if I had a machine to try it on....
With a full season behind me I can say my opinion of this trimmer has continued to improve since I wrote the original review. The key thing has been to get it adjusted correctly. This keeps the lines out of the dirt and rocks.
One of the downsides is that if the tractor hits a bump and goes up while the arm is back (as seen below) it will angle the cutterhead down drastically and scalp around that post. This is greatly reduced if you ignore DR's recommendation and leave it locked in "transport" mode rather than putting it into "float" mode:
Aaron Z
I have yet to use or need the "float" or "pivot trimming" mode. DR's recommendation is that you lock the unit for "parallel trimming/mowing (terrain that is level with Tractor Wheels)" and use the pivot position (float) for "pivot trimming/mowing (terrain that is higher or lower than Tractor Wheels such as ditches)". Some of my fence lines are on pretty rugged terrain yet the parallel or locked mode always works fine.
It's also important to use sufficient RPM. In recent use I haven't broken any of the lines outright, and after mowing yesterday the lines show only an inch or so of wear after about a mile of cutting. This included some pretty rough brush. The idea of steel line is interesting, but the plastic is doing well enough for me that I don't think it's necessary. I did end up returning to the 0.175 line. With improved adjustments and technique I find it's probably better than the .155 line.
I'm also impressed with the strength and durability of this trimmer. I have unintentionally abused the heck out of it and it still works fine. The details would make you cringe.
The remaining shortcomings are mainly a result of using a larger tractor: I still have to be careful not to lift the unit too high so that the drive shaft doesn't make contact with the 3-point triangle. And I could use more reach, as I can't center the trimmer head in the fence line when I'm on the downhill side of the fence.
/ Using DR PTO trimmer on Cat 2 Tractor? #134
I gave a hard look at their self powered model a few years ago, but passed it up because I didn't want an extra motor to maintain. I did a search but I couldn't find the video she told you about, I would like to see it in action.
The question I have is how often does it need new string put on --- every 100 feet? 500? 1000? I like their idea but I think I will hold out for one with a metal blade.
There's a blade!
Sent from my LON-L29 using TractorByNet mobile app
FWIW Titan is now offering a similar cutter and much lower cost than DR.
Titan 3-Point Hitch Attachment Trimmer Lawn Mower Category Cat 1 Tractor
It's always good to have competition. But the cost difference is only about $150 at the moment, so other factors could easily be more important. Also, DR Power is offering free shipping at the moment, so theirs may even be less money overall. Titan doesn't give a "reach" spec, but the diagrams make me think it's no more than the 63 inches of the DR Power unit. Longer reach is the only thing that might make me want one.
/ Using DR PTO trimmer on Cat 2 Tractor? #138
74 1/2" from center line to outside of trimmer guard. DR Claims 63".
So, 11 1/2" wider.
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
