Miller Dialarc
/ Miller Dialarc #41
Believe it or not, my partner and I buy and restore stick welders, primarily Dialarc and Idealarc machines. We blow them out with all the sheet metal off then use a pressure washer and mean green to clean them up. They look like new with the years of grime off. We let them set for several days prior to power up. Never had a problem
/ Miller Dialarc #42
My Miller jumpers check out like that diagram, set for 200 volts. But why does it have a 200 volt setting when my house and garage has 220 incoming volts? Is 200 and 230 volts for another country maybe?
I'll try to find that online manual for JH... siries later on, be a good rainy day search. You've been great help thanks :thumbsup:
No problem, just put the jumpers on for 230 volts instead.
The service at my place is 247 volts, but further down the line at other houses it would be less.
I put my jumpers at 230 volts and just know that the settings list on my door for my millermatic 210 will actually be a little hotter than listed.
Miller even makes a note of that on my door chart.
/ Miller Dialarc #43
Really, so if mine breaks down you would know how to fix it? You sell them after there cleaned out?
I just used compressed air to blow out the dust, the dust probably wouldn't of bothered any but I had the side panels off, I did have one scare tho, after blowing the dust out, I put the panels back on, flipped the switch on and it tripped the breaker, reset the breaker and hit the switch again and it started, ran some rods, turned it on and off several times and it started, must of been a fluke.
/ Miller Dialarc #44
They are very simple welders. We have never found one that we couldn't fix. Basically we clean then, check and clean all connections and powder coat the sheet metal. We even have some custom diamond tread hoods we put on some. Like this:IMG_5985.JPG
/ Miller Dialarc #45
Wow, that is a nice rebuild job, it sure does looks new, what's the selling price on something like that?
/ Miller Dialarc #46
Last night after reading your post I was wondering why set the jumpers at the 230 when I have 220 volt entrance service, so when I got home tonight I took my multimeter and started checking some outlets, they all seem be to around 120-121 volts and for some reason I always thought they was 110 volts, so if I add 110to 110 that equals 220 volts, but now if I add 120 to 120, that makes 240. So now it makes sense to set the jumpers at 230 volts, after I did that I tried out the welder again on the 250 amps AC setting and it seems like the AC buzzing has a smoother buzz. Now the only puzzle I have is what why where did I get the 110 and 220 volt formula from.
/ Miller Dialarc #47
This is the first test run of the Miller Dialarc, truck springs makes pretty good scrap steel to test on. The last couple passes was in the 140/310 AC setting, dial at 60 with 3/16 6011. I took the springs out of the vise and the following night, some separation started, probably if done with 70 rod it would of stayed together.
/ Miller Dialarc #48
From what I've been told, the U.S. started increasing the voltage around the 1950's and that 110/220 is just the old way of saying it that has lingered.
Here is a brief summary: North American Voltage
Other references will go into greater detail.
/ Miller Dialarc #49
Ok then you did two things, you verified that I wasn't gone totally senile/crazy yet and you've shed some light on my age. I thought I remembered that 110 volt was the standard out input/output for outlets. That was a good short somewhat understandable link. >>>
("110Volt: Outdated and typically no longer supplied by utilities.
115Volt: Outdated and typically no longer supplied by utilities. However, 115 volts nominal may be referred to by equipment design standards as this is the Nominal Utilization Voltage as defined by ANSI C84.1.
120Volt: 120 volts is the common lower voltage supplied by US and Canadian utilities. It is provided by the utility as 120 volts ±5%.")
/ Miller Dialarc #50
A lot of the schools in the mid west still are wired for 208V. So 208,220,230,240 should all run on the same hookup for USA made products. Some European machines are too fussy so they need to be switched to the exact voltage. I know some ESAB plasma cutters will not run on 208V unless they were ordered for 208v. The other one is the same 110,115,120v. No idea if the voltages actually increased or if only the numbers did.
/ Miller Dialarc #51
For consumer products having absolutely 60hz AC is FAR more important than having the right voltage. As long as it's in the right ballpark, you'll be fine. Also voltage drops depending on how much wire to are going through & how far from the transformer on the pole.
In Afghanistan the power was at 50hz instead of 60hz. Every clock needed resetting every few days as they would loose several minutes a day. The AC frequency in the US power grid is actually synchronized to the GPS signals to be uber precise (and to synchronize all the generating plants).
/ Miller Dialarc #52
The schools are wired that way, but what does multimeter say at the service input or at your service entrance? according to the article I read that's outdated voltage.
/ Miller Dialarc #53
How is someone supposed to measure 60hz, is that on a multimeter?
/ Miller Dialarc #54
A fancy multimeter, or an oscilloscope. But while voltages may be off, you can be guaranteed that something tied to the US power grid is running at 60hz. It's possible but extramely unlikely a small local power company might not be tied to the grid. Even less likely that non-grid power company isn't putting out 60hz.
If somebody pumping power into the grid isn't precisely synchronized with the grid they won't actually be pumping power into the grid.
/ Miller Dialarc #57
I've got a killawatt & it's handy for determining power draw & pretty cheap. Will be using it as a backup frequency meter for setting the throttle on my tractor when running my PTO generator.
/ Miller Dialarc #58
Want to up the ante on breaker size for my Miller Dialarc from 50 amp to 70 amp, like to stay under my 100 amp cable size, but the outlet says 50 amp and the 100 amp cable is a really tight fit but it's in. I've been the past hour trying to find a 100 amp outlet and cant find one, all I see is the size I already have, should I just keep using this size or what?>>>>>> Leviton Surface Mount Receptacle 2 Pole 3 W 5Amp 25V Nema 6 - 5 R Blk Csa Cd | eBay
/ Miller Dialarc #59
It's the reason they normally get wired to either a shut off box or straight to the breaker.
In my case I wired straight to the breaker and shut off the breaker when done for the day.
My Airco 300 (Miller 330 abp) can pull over 100 amps.
/ Miller Dialarc #60
I wonder if that meter is important for testing home generators, or generators on a building construction site so a coffee maker will work right?
I used it on my Miller bobcat 225nt and found the idle was a little low so the Hertz was low - this incorrect output caused a small mig plugged in to behave very strange.
Miller tech support is who told me to check the Hertz when I described the problem.
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
Caterpillar 950F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950F...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
