John Deere 5525 electrical problem
/ John Deere 5525 electrical problem #1
Patmgn
Converse, louisiana
John Deere 5525
My cab 5525 will not turn over, when I turn the key none of the gauges or lights come on but when I turn the light switch on the dash on the head light and blinkers work but nothing when I use the key....why don't I have power going to the ignition?
/ John Deere 5525 electrical problem #2
Start by cleaning battery cables & ground, then check fuses.
Ronnie
Ronnie
Thanks for help, i found the fuse blown, changed it soon as I turned the key it blew again. Gotta start looking for for the short
/ John Deere 5525 electrical problem #4
Patmgn
:welcome:
One way to find a short, and not keep blowing fuses, is to rig a 12v bulb to plug into the fuse spot. If a short, the bulb lights up. When the short is tracked down (moving wires around, or lifting them from their terminal) then the light goes out. Saves blowing fuses.
/ John Deere 5525 electrical problem #5
Which fuse are you blowing? I have a include a link to your operators manual.
If it is "26-Fuse F18, 10-Amp: Fuel Shut Off Solenoid, HVAC Relay, Elx Relay, Seat Switch, and Wheel Speed Sensor ", I believe the problem is the thermistor sensor (thermistors are temperature variable resistors used as sensors.). On the thermostat housing there is a sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
When the sensor on the thermostat housing fails it shorts out and blows the fuse. Try unplugging it, replace fuse and see if it starts and runs. The part # is RE503242, if you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
If it is not this fuse let use know which one.
http://manuals.deere.com/omview/OMRE260580_19/?tM=FR
/ John Deere 5525 electrical problem #6
You can disconnect the CSA & it will still start . It has been a big problem with the 5000 series, including mine.
Ronnie
/ John Deere 5525 electrical problem #7
One would think after over 20 yrs of CSA failures JD engineers would have arrived at a solution to the sensor failures but I guess they enjoy the parts revenue.:D
/ John Deere 5525 electrical problem #8
Reviving an old thread…
What if you’re having this exact problem with the same fuse being blown but the CSA (cold start advance) is not the problem. I’m having the same issue and I’ve unplugged the CSA but still having the F1 key switch fuse being blown as soon as the key is turned on.
/ John Deere 5525 electrical problem #9
4320 blows fuse when you turn on ignition switch . lights & acc work with switch off . Have changed ign switch and have disconnected thermostat sensor . still blows. I was just taking tractor to shed when it just died . Any advise besides thaking it to jd dealer and paying $159 / hr ?
/ John Deere 5525 electrical problem #10
Welcome to TBN
Put a light bulb in place of the fuse that blows. Then look for what is shorted out. When the bulb goes out, you have found the problem.
/ John Deere 5525 electrical problem #11
yes .. well I've been using a cicuit breaker mini fuse instead & it resets after it clicks . It seems odd the it would be a wire short . After reading of sensors shorting out . It would be great if i could get the schroud off around the seering column .
/ John Deere 5525 electrical problem #12
I had this exact same issue last week on my 5083e, and it was the cold start sensor. Unplugged it, and it fired right up and ran fine. Went to the dealer and got the sensor, and he said he had sold 3 of those the day I was there. Talked to the service manager and he said most people just unplug it and leave it, as it seldom gets cold enough to need it here.
If that is not the sensor that is your issue, try other ones. There are a couple I believe around the injection pump. Could be the fuel pump solenoid.
Good Luck
/ John Deere 5525 electrical problem #13
You need to find out everything on that fuse. See if the service department will print that section of the wiring diagram for you. Then disconnect each item. If the fuse still blows, it's wiring, if not it's something you disconnected.
/ John Deere 5525 electrical problem #14
Usually when the lights work but it won't operate the starter, you have a bad connection. I mean battery post, or maybe the end of a big cable. If it has gas station add on ends, clean it up. Scrape inside of terminal out, clean battery post to make it shiny. If still persists, I have taken cables loose and hammered the crimp tighter. Be sure to remove both ends of ground and clean. Is battery health good? Bad connections also affect charging. My dad bought a $300 solenoid, after I told him it was a cable. He was so sure, and he is an electrician. But he ended up using the solenoid on the string cutter on the hay baler, since he had an extra, good one, because it was a cable after all.
/ John Deere 5525 electrical problem #15
Where does the operator presence switch plug into. I am assuming this is why the power reverser does not function.
1993 International 4900 Utility Flatbed Truck (A60352)
1993 International...
2025 Auger Bit Skid Steer Attachment (A61567)
2025 Auger Bit...
832732 (A61166)
832732 (A61166)
8' DISC HARROW (A60430)
8' DISC HARROW...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
