hyd problem on jd2030
/ hyd problem on jd2030 #42
I do believe you have to make your fittings and that thread is 3/8 NF and the gaugethread will be 1/4 bsp... add a hyd hose to your gauge for flexibility
/ hyd problem on jd2030 #43
I put my gage on one of the ports and got 1900# at idle. So the pump is working?
An adjustable bolt can be accessed under pump held in place by a jam nut so that hyd pressure can be raised to factory setting at 2250 psi
The treads on that bolt is a hair smaller. Would it be a metric tread
I never had a hyd pressure problem on this tractor, do I need to adjust it. Also if the pump is working how come I don't have fluid going to SCV.
/ hyd problem on jd2030 #46
You don't have to adjust stand-by pressure BUT JD engineers must have thought hyd system would operate better @ 2250 psi or they would have set stand-by at lower psi. Possibly pressure control valve is blocking flow to scv.
When I put new O rings in pressure valve I didn't see anything wrong in there. It was clean, spring looked good. I don't see how that can mess up. How do I diagnose that.
Ok this is what I did, I took off the pressure control valve outlet line going to the SCV. I put my gage on the line and started tractor. The gage read 1900# just like at the pump, so my thinking is the PCV is working correctly, you tell me if i'm wrong here.
Then I took my coupler off tractor, (I only have 2 hose connections). I connected my gage to one line and blocked off other line and started tractor, I had 1900# at gage when i worked lever. I then took of gage and put on other line and blanked off other line like before and started tractor, I don't have no pressure out of that line. Is my SCV bad or needs adjustment? Keep in mind I just bought this and its been rebuilt by a good company. Any suggestions?
LOOK! (A63109)
LOOK! (A63109)
2001 PETERBILT 378(INOPERABLE) (A63569)
2001 PETERBILT...
Club Car (A59231)
Club Car (A59231)
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
