Ballast Can you ID what this ballast or weight was used for?
   / Can you ID what this ballast or weight was used for? #1
462
NW Florida
Kubota M7040
Hello all,
I picked this up at a garage sale awhile back. It's about 15 inches wide and 10 inches tall as it sits in the photo. Some old gray paint still present in places. Haven't weighed it but guessing it's about 40-50 lbs. Is this a tractor weight or maybe for something else?
In buying it my first thought was to repurpose it as a poor man's anvil, then I thought about chunking it into a 3 point ballast barrel I'm in the process of building. Before I do either does anyone know what it was used on originally?
thanks,
Dave
   / Can you ID what this ballast or weight was used for? #2
It looks like a front ballast weight, made before the 'suitcase' weights became standard.
You see them underneath the front of vintage tractors (no FEL) to counterbalance attached implements off of the back.
Thanks Wagtail, I was guessing it might be from an old Ford or something.
Cheers, Dave
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
