Ignition switch problems
/ Ignition switch problems #1
cliffoflancing
LEBANON TN
MITSUBISHI D1600 FD
Mitsubishi D1600 FD Grey Market Tractor, Ignition switch, replaced a couple and they last about 1 year then become inoperative. Does anyone have an answer to this problem ?
/ Ignition switch problems #2
Many switches are exposed to water and sun.
That being said the lubricants inside get kinda fried, stiff and prevent good contacts.
Having dissected a few I noted the causes.
My cure has been to squirt some WD40 into the key slot which in most cases cured the problem.
Try it it casts peanuts!
Good luck.
I suggest WD40 as it is non corrosive.
Good luck.
Thank you PILOON for your prompt reply.
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
2020 Autocar Xpeditor T/A New Way 31ASL 31Yd Side Loader Garbage Truck (A61573)
2020 Autocar...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
UNUSED SWICT 66" BUCKET (A64280)
UNUSED SWICT 66"...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
