Loader hydraulic lines
/ hydraulic lines #1
claymoore
Central New York
bx2230
Greetings ,new member here.I have been trolling on this site for 6 months and now I need some assistance. I have a bx2230 and it developed a pin hole leak in one of the metal lines, right where the brace holds it down in front of my left foot. I have had no luck finding a exploded view or a part number. looks like an easy fix.any help would be gratefully appreciated, I am continually amazed at the knowledge on this site. Thank You .
/ hydraulic lines #2
Did you look here?: Kubota Parts | Buy Online & Save
/ hydraulic lines #4
Is this what you are looking for?
Here's the link of the parts breakdown: Kubota BX223D Parts Diagrams
Added in Edit: Sorry the link won't take one directly to the drawing. After selecting link above, selected Pump/Motor System along the left hand side, then select J21500 HYDRAULIC OIL LINE(STEERING).
/ hydraulic lines
/ hydraulic lines #7
Heck I'd remove that line and have someone simply braze a blob of brass over the pin hole, maybe even silver solder but brazing would be better.
/ hydraulic lines
Hey guys ,thanks again for the help. Well I got the line put on Friday night (4 Hrs later) .Wasn't easy but I didn't figure it would be .Hint to any one doing this,Take off the mower ,I wish I had. Also be prepared to remove the bracket that your FEL mounts on to. line came apart fairly easy. 15 year old tractor.Changed hyd. fluid and filter,so I am good to go! thanks again everyone!
/ hydraulic lines #9
Mine got hit by a grinder by accident when my neighbor was welding something else. But they were all corroded, so I replaced all 3 of mine for about $90. Removing the left rear wheel helped also.
/ hydraulic lines #10
My first post recently - tho' I was here ~15yrs ago, and got lots of great info & support.
....Hint to any one doing this,Take off the mower ...
That's easier said than done when you have no hydraulic pressure - that's my challenge this afternoon.
Hehe - I'm currently facing a similar problem on my BX2200 FEL lines. The middle of the three ~15 inch hard lines that come up from under to near my right foot, failed quite dramatically - an oily shower head. I'll start a separate thread, but I'm seriously considering selling my (~17yo) BX2200 as I'm getting very tired of playing the hydraulic repair guy every year and cleaning expensive UDT off my driveway & re-seeding my lawn from the oil-kill yet again!
I seem to regularly have hydraulic problems. Last year I had to replace the 3 long hard lines to the steering. The year before one of the FEL flex lines broke and another was dripping. A number of years before I replaced all three FEL hard lines. [Let's ignore the ~$1500 RCK60 gearbox that turned to metal shavings last year when a seal failed].
I *think* the problem is that the BX2200 has too low ground clearance for my non-lawn use and the very low positioning some of the lines tangle with ground brush & even get bumped going over small logs or rocks.
I'd be interested in other's opinions of these small Kubota hydraulic issues - is this a syndrome, or am I just unlucky ?
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
