Loader hydraulic lines
/ hydraulic lines #1
claymoore
Central New York
bx2230
Greetings ,new member here.I have been trolling on this site for 6 months and now I need some assistance. I have a bx2230 and it developed a pin hole leak in one of the metal lines, right where the brace holds it down in front of my left foot. I have had no luck finding a exploded view or a part number. looks like an easy fix.any help would be gratefully appreciated, I am continually amazed at the knowledge on this site. Thank You .
/ hydraulic lines #2
Did you look here?: Kubota Parts | Buy Online & Save
/ hydraulic lines #4
Is this what you are looking for?
Here's the link of the parts breakdown: Kubota BX223D Parts Diagrams
Added in Edit: Sorry the link won't take one directly to the drawing. After selecting link above, selected Pump/Motor System along the left hand side, then select J21500 HYDRAULIC OIL LINE(STEERING).
/ hydraulic lines
/ hydraulic lines #7
Heck I'd remove that line and have someone simply braze a blob of brass over the pin hole, maybe even silver solder but brazing would be better.
/ hydraulic lines
Hey guys ,thanks again for the help. Well I got the line put on Friday night (4 Hrs later) .Wasn't easy but I didn't figure it would be .Hint to any one doing this,Take off the mower ,I wish I had. Also be prepared to remove the bracket that your FEL mounts on to. line came apart fairly easy. 15 year old tractor.Changed hyd. fluid and filter,so I am good to go! thanks again everyone!
/ hydraulic lines #9
Mine got hit by a grinder by accident when my neighbor was welding something else. But they were all corroded, so I replaced all 3 of mine for about $90. Removing the left rear wheel helped also.
/ hydraulic lines #10
My first post recently - tho' I was here ~15yrs ago, and got lots of great info & support.
....Hint to any one doing this,Take off the mower ...
That's easier said than done when you have no hydraulic pressure - that's my challenge this afternoon.
Hehe - I'm currently facing a similar problem on my BX2200 FEL lines. The middle of the three ~15 inch hard lines that come up from under to near my right foot, failed quite dramatically - an oily shower head. I'll start a separate thread, but I'm seriously considering selling my (~17yo) BX2200 as I'm getting very tired of playing the hydraulic repair guy every year and cleaning expensive UDT off my driveway & re-seeding my lawn from the oil-kill yet again!
I seem to regularly have hydraulic problems. Last year I had to replace the 3 long hard lines to the steering. The year before one of the FEL flex lines broke and another was dripping. A number of years before I replaced all three FEL hard lines. [Let's ignore the ~$1500 RCK60 gearbox that turned to metal shavings last year when a seal failed].
I *think* the problem is that the BX2200 has too low ground clearance for my non-lawn use and the very low positioning some of the lines tangle with ground brush & even get bumped going over small logs or rocks.
I'd be interested in other's opinions of these small Kubota hydraulic issues - is this a syndrome, or am I just unlucky ?
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
Compressor (A55973)
Compressor (A55973)
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
DEUTZ MARATHON...
John Deere 50 (A60462)
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
