Installing new septic system in progress
/ Installing new septic system in progress #21
My leach line has 15' of gravel under it, 40' long. Plus the soil drains in no time. I was there when it was installed but did not do it.
/ Installing new septic system in progress #22
The leach line length and depth is a factor of soil type and the room you have for the field. The rock amount is figured by the square foot- in other words soil type and home size (typically number of bedrooms) are put into a formula that will generate a figure which is the square feet of leach field rock.
So you can have a 4' wide trench with 1' of rock below the pipe or a 1' wide trench with 4' of rock below the pipe.
/ Installing new septic system in progress #23
Al The D-box would have been easier. Your right about the size.... 3br system, but I'm building a quaint cozy 2 bar now that the kids are grown and gone.
I think rather than a T I would use a Y which is pretty standard in any sewer system. 90 degree turns always ask for trouble in sewer systems
/ Installing new septic system in progress #24
I understand. I am a Master Plumber by trade. The amount of gravel was more a favor by the installer rather than what was needed. He is a good friend who I worked with for many years.
/ Installing new septic system in progress #25
I think a tee is better than a D box. Here is a picture of the failed lid on my D box. Long story short, we had back up in the basement. Now I do not have a D box. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=511958"/>
Yikes! I suppose that's a good enough reason! My D-box is only about 6-8" underground. Luckily it's out of the way and not something I'll accidentally run over. (Knock on wood)
28ft. TV Tower (A65640)
28ft. TV Tower...
2007 Jeep Commander (A62613)
2007 Jeep...
International 311 6ft. Pull Behind Mower (A65640)
International 311...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
