rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,927
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Pretty flat terrain, river bottom land with soft soil and no rocks.
I know I'm no expert, but I really can't see the need for a 40 horse. I'll keep looking though, I've got time to find a deal.
Do dealers run specials at certain times of the year?
The reason for the 40 horse is only partly to do with the horse power. Horsepower in tractors also is the way that tractor manufacturers decide on a whole raft of other things like traction, transmission type, loader capability, stability, ground clearance, 3pt category, accessories, PTO type, instrumentation, and even convenience features like space for your feet and lunch bucket, weather protection, and even the quality of the seat. When the horsepower doubles, all these other things do too.....as does the cost and the reliability. That's why several people have recommended going larger and used. That's because the main downside to larger is the cost.
To your questions: Soft soil often requires more power and traction. That absolutely means 4wd, power steering, and an increase in horsepower. But soft soil without rocks also says that the post hole drill you mentioned will work very effectively for you. Note that a 3pt post hold drill is driven by the PTO - Power Take Off - so the tractor needs to have what is called a "live" or variable speed independent PTO of the kind that is controlled by it's own PTO clutch. The post hole drill is raised and lowered by a 3pt hitch so it sure helps to have quite a bit of range and lifting ability - both of those abilities are much improved when the tractor has the capability of a category II 3pt hitch. Plus the tractor needs enough weight and stability to resist the torque of the auger. You will occasionally "stick" the auger. Everyone does... A heavy tractor and strong 3pt hitch will come in very handy when that happens. Sure beats a shovel...
None of those things are directly related to horsepower, but all of these things are features you will find commonly in tractors having 40hp and up....but they are question marks in smaller machines.
Dealers do run specials at certain times of the year, but not as often as car dealers do. After all, car dealers have to move models based on model years. For them, turnover is everything.
Tractors are different. They don't have model years. Their "year" is based on when they are sold; not when they were made. So tractor dealers expect to keep unused inventory warehoused longer. Much longer.
Rather than look for a special time of the year I would look for a dealer whose philosophies match your own. That will save you more money than special deals.
luck, rScotty
