$11,000 Water Bill
   / $11,000 Water Bill #182
nice job on article, except for you west coast guys, it's Carolina ;)
a close friend had exactly this same thing happen this month when a fitting on her boat dock water line broke and she pumped
city water into the Pamlico River for quite some time. They told her to write a letter and they would consider it one time.
   / $11,000 Water Bill #183
I knew there had to be a typo in there somewhere. Thanks for catching that!
   / $11,000 Water Bill #184
This thread has now been summarized in article format for easy reading: Leaking Pipe Leads to Insane $11,000 Water Bill | TractorByNet.com
Quote from your article
"Turns out the plumber who ran the pipe used DWV pipe, which stands for Drain Waist Vent and is not intended for use in 50psi pressure lines. "
On post #23 there is a picture of the pipe used. While DWV is marked on the pipe, that is just one of many rating on the pipe. I'm at a loss why so many people focused on that marking, but ignored where its rated for 280 psi and the ASTM D1785 stamp that means it's used for pressurized liquids. This pipe can be used for BOTH drinking water and DWV lines.
If the run had been shorter, and the cement applied perfectly, there would never have been a problem.
   / $11,000 Water Bill #185
My understanding is that the builder is going to use HDPE rolls this time. I have read mostly positive reviews about it and we actually have it in use out here in Iraq - its pretty tough stuff. By far the biggest advantage is the fact that we will only have 3 connections over our 1300 foot run. PVC is a good product, but all 50+ joints need to be perfect.
Do you have any what size the pipe will be? As big as the original? He has to make his money up somehow so my instinct is he will use 1" and maybe 1-1/4" at the most. So with the profit he made on the 2" original pipe he will still come out in good shape.
I really think you are better off using a smaller pipe with a higher pressure anyway because that way if you have a leak or a crack you should notice it in the house faster. That is the stuff I would put in regardless and should hold up for a long long time, as long as you don't live in Texas.
   / $11,000 Water Bill #186
Glad it got resolved, was trying to figure out a rural area that has public water though?
None of that where I'm from? Doesn't seem too rural if it does.
   / $11,000 Water Bill #187
There are a bunch around here, especially in new houses.
Aaron Z
   / $11,000 Water Bill #188
So it's a town water supply? or one big well and holding tank supplying multiple homes??
Sounds more like a neighborhood than "rural"
Hope they have natural gas like that too! HEck we can't even get high speed internet
   / $11,000 Water Bill #189
I'm on rural water here. It covers a big area, water mains, a water tower and all.
   / $11,000 Water Bill #190
My water main went in a couple of years after they paved the gravel road
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
19010 (A48082)
19010 (A48082)
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
1043 (A50459)
1043 (A50459)
