Weight Distribution Hitches
/ Weight Distribution Hitches #1
richriddle
Gold Member
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
I need a weight distribution hitch for a car hauler that hauls the tractors and skid steer. The max weight of the heaviest thing it will haul is about 6,000 pounds and the truck is rated to haul 11,300 total. What hitch do you folks recommend? Watching youtube showed some basics, but it didn't really show how you mount the side pieces to the channels of the trailer. My trailer has 6" channel. Thanks.
/ Weight Distribution Hitches #3
That Anderson setup looks good, but I think the spring bar system is quicker to adjust for those of us who have various weights on the trailer. As long as they both work, no problem. My system came with my truck by Nissan, so I don't remember which brand it is. I still find it amazing that the system actually levels out the rig.
/ Weight Distribution Hitches #4
So what happens when you unload the tractor from the trailer while the chains still have tension on them? Or with the spring bar setup? Sometimes I load/unload my tractor 5 to 6 times in a days time. Just wondering. Thanks, Jon
/ Weight Distribution Hitches #5
Take a look at the Equali-z-er brand hitch.
I have had several, and currently am using their 14,000 lb. model.
E-Trailer sells the Equal-i-zer 12,000 lb. model .... # EQ37120ET.
The Anderson is very unique, but the Equal-i-zer is bullet proof!
The chain style units restrict backing with the hitch attached.
Thank you for the recommendations and opinions. The information and reviews on the Andersen and Equal-i-zer models show that both rate very high. It appears as though the Andersen has a clone called the Husky 32218 that sells for about half the price of the Andersen unless I am missing something of significant difference between the two models.
/ Weight Distribution Hitches #7
The difference between the Anderson and the Husky and the other brands that use spring bars, is the Anderson uses the red bushings for the spring.
The sway bar is built into the ball.
I used a round bar weight distribution hitch for a few years with my campers and when I switched to the Anderson It was so much easier to hook up and it
towed so much better, no more bounce, no more adjusting the sway control bar, no more noise.
/ Weight Distribution Hitches #8
A second vote for the Equali-z-er brand hitch, been running one for about 10,000 miles, 5 years. On a 12K trailer. My prime thing was to get something that fit before I learned to weld but it seems to do well.
/ Weight Distribution Hitches #9
The Husky 32218 looks to me, like a Chinese attempt to clone the Equal-i-zer.
The Husky IS made in China, and IS less expensive than the Equal-i-zer.
The Equal-i-zer is made in the USA, and is made of 100% USA steel.
The Equal-i-zer quality is superb!
Having had several Equal-i-zers, I would not even consider buying anything else!
/ Weight Distribution Hitches #10
I've had no problem loading and unloading with the hitch setup for the load.
I also have had no problem while backing. Am I supposed to?
Thank you for all your assistance. There are some very unique methods you folks offered in new technology for weight distributing hitches. Before this thread, I had only thought of the old design. You have great insights and guidance.
/ Weight Distribution Hitches #14
Is there a trailer load weight where it makes sense to use a weight distribution hitch? Used them with RVs before. Wasn't thinking of one pulling tractor and bush hog on trailer. Any rule of thumb to follow for when they are helpful?
/ Weight Distribution Hitches #15
Lots of OEM hitches & vehicles specify a WDH is required after x tongue weight. Usually around 500-600lbs or so.
/ Weight Distribution Hitches #16
Holy Toledo, I didn't think those hitches were so expensive, this is why I bought a class 5 hitch for my half ton pickup.
I bought a Curt hitch and it will haul 15,000lbs with 2500lb tongue weight, it far exceeds my truck but I wanted to avoid not having enough hitch, I paid $280 for it with free shipping, install took about an hour on a virgin frame.
I have a 7500lb Reese ball for a hallow 6k ball mount for smaller trailers and a 2 5/16 16k curt ball mounted on a solid 15k Reese ball mount, now I never have to worry about hauling anything.
My truck also has coil over rear shocks which are fantastic for towing, I can haul a 6-7k load and the truck rides level and barely knows it's back there.
I would invest in heavier rear shocks and a heavier hitch first. I'm not sold on the weight distribution hitches, feels like a bandaid solution to me.
/ Weight Distribution Hitches #17
A WDH isnt any more of a bandaid than heavy rear shocks or bags, quite proably less. Trailers pushing down on the rear of a truck behind the axle will intrinsically act like a lever & try to lift the front axle. A WDH transfers some of that weight to the front axle via springs twisting the hitch forward.
The real solution is to properly put the weight directly in on or infront of the rear axle. A gooseneck or 5th wheel accomplishes that. Anything behind the axle has the potential for the tail to wag the dog due to the lever that is the distance between the hitch & axle. When that trailer pushes left on the hitch, the front of the tug gets pushed to the right. The same goes for vertival mltion. Some WDHs have sway control built in, others have a friction bar slapped onto the side. Between the 2 they can do a fair bit to mitigate sway, porpising & your *** dragging without the need for an excessivly stiff suspension.
/ Weight Distribution Hitches #18
I agree with Fallon. I use a WDH when hauling my tractor & bush hog. The unit spreads the weight over all the axles, keeping you in control of your combination. Dead weight on the tongue is normally 500 pounds. That raises to 1000 pounds with a WDH in many cases. You still should not overload or underload your axles.
/ Weight Distribution Hitches #19
I failed to mention, the WDH is a little more work. I do not use it on a load that would yield a tongue weight under 400 pounds.
/ Weight Distribution Hitches #20
Forgot to mention - I like the Equalizer but I have not tried others.
There are only 3 main parts to move around - The hitch ball and shank (which weighs 54lbs) and the two sway bars (21lbs @). Plus I carry a killer farm jack in the truck to hitch it up easily.
My feelings exactly, especially since the three parts I mentioned weigh almost 100 lbs by themselves. Seems like when I bought it 5 years ago it wasn't as heavy :)
Maybe it's a symptom of old age and conversion to metric. I'd swear what used to be 50lbs feels like 50kg :)
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
John Deere 318G Skid Steer (A63689)
John Deere 318G...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
