Kubota 305 will not start
/ Kubota 305 will not start #2
There's a safety switch on the clutch pedal linkage - the switch is on the right side by the brake pedals. It's position is adjustable - its also possible to test it by unplugging the two wires and plugging them into each other, temporarily bypassing the switch. Don't leave it defeated - not safe.
Thank you! Thank You! With your input I found the switch and one of the wires had been pulled out. Now, its starting up fine!
