Back Up Camera for UTV
/ Back Up Camera for UTV #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Anyone recommend a large screen, easy to install back up camera for a UTV (Kawasaki Mule Pro FX)?
I can't find any good mirrors that would fit the Mule and have neck problems so thought a camera might be the answer. Thanks.
/ Back Up Camera for UTV #2
You might want to look at the Cab Cam camera systems. They have a wireless camera system that you could use with little installation effort as you do not need to wire it into the reverse/back up light wiring like you would with a truck(in my case) or a combine.
You could install two cameras on both sides of the rear wall of the cab on the utv using the wireless cameras with a multi camera screen system and prevent any blind spots.
You can also buy less expensive wireless remote cameras that simply attach with a heavy magnet and then remove it when you are done.
I have had the two cab cams in my truck for almost 7 years now and it has been a blessing as the truck Isuzu I290 is very long and creates huge blind spots when backing or advancing forward I have the two cameras mounted on the front bumper and the rear step bumper of the I290.
/ Back Up Camera for UTV #4
I have two cameras and monitors in a box (for a year or so) but just haven't hooked them up. Cost about $30 for camera and monitor on ebay buying seperately. I saw a wireless camera and monitor for around $40 for both last week but figured the two I have was enough. Check ebay and Amazon before spending big bucks for items that are now dirt cheap.
2001 GMC C6500 Dump Truck, VIN # 1GDJ7H1EX1J901196 (A65563)
2001 GMC C6500...
New Holland 463 Disk Mower (A66408)
New Holland 463...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
