Looking for garden tractor with tiller
/ Looking for garden tractor with tiller #1
REt92
Member
JD 1010 JD 3005
Does deere make a garden tractor that has an easily attached tiller that stands up to use? Thanks
Ret92
/ Looking for garden tractor with tiller #2
The x700 series with rear pto and 3 ph works well with an IMatch hitch and the 647 commercial rated tiller.
You can get the autohitch which connects the pto driveline with this package too. This allows you to back up and connect the tiller complete without leaving the seat. Only leaves you with raising the tiller parking stand.
/ Looking for garden tractor with tiller #3
In addition to the X700 series & depending on the budget it might be worth a look at the 1Series.
Depending on models compared, not a lot of difference in price.
/ Looking for garden tractor with tiller #4
That is a good point. Depending on your needs a 1023E/1025R may be more cost effective than a X7xx series tractor once you add the 3 point and rear PTO, especially if you are looking at a diesel.
/ Looking for garden tractor with tiller #5
I really like the 4x4ws on the x749 diesel and it will out maneuver the sub cut models. It is too bad Deere quit building this model. That said the 1025R is better at being an 8 in 1 tool with fel capabilities and a better 3 ph and rear pto standard.
It would be great if the sub cut tractors were available with 4 wheel steer that would be very appealing to more people.
/ Looking for garden tractor with tiller #6
Does deere make a garden tractor that has an easily attached tiller that stands up to use? Thanks Ret92
What kind of soil and how large an area are you looking to till?
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
159115 (A60430)
159115 (A60430)
2275 (A62131)
2275 (A62131)
BOMAG BW213 PD-2 PADFOOT ROLLER (A62129)
BOMAG BW213 PD-2...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
