Oil & Fuel injector pump 770 jd
/ injector pump 770 jd #2
Is there a question here? Hope we can help...
/ injector pump 770 jd #3
shoot me your email, I have a PDF of th eDeere tech manual you're welcome to
Joe
/ injector pump 770 jd #4
An injector pump needs to be tuned to your machine. Unless you have to tools and know how its off limits. Take it in. The injector pump will have some sort of positive locks to prevent them from being twisted. I dont recall the exact reason but dont touch the injector pump. I do all my own work,,,except that.
/ injector pump 770 jd #5
I'll suggest to acquire a 770 tech manual and follow the IP R&R instructions. R&R of inj pump isn't that difficult if one has mechanical skills & can follow instructions.
/ injector pump 770 jd #6
TX JIM & the others are correct.. GET THE BOOK/PDF.. & mark your gears.. its doable & you'll save about 500.00 in labor costs.
Good luck..
Whats wrong w/ your pump?? Did you remove the side cover yet? It might be something as simple as the control rack is stuck..
Engine oil was full of fuel wouldnt even turn over
update!!! fuel had seeped through pump into pistons.removed injectors,,cranked engine, cleared fuel out. removed pump sent off for rebuild, installed pump yesterday up and running all is good so far thakns for every ones input.
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
2017 Ford Transit 150 Cargo Van (A66736)
2017 Ford Transit...
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
2008 CHEVROLET SILVERADO 3500 4X2 S/A SERVICE TRUCK (A69167)
2008 CHEVROLET...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
