Walking Beam Trailer
/ Walking Beam Trailer #21
The walking beam trailers are much more stable in ride than a regular trailer. I believe someone posted a link to a video demonstrating this. That does not mean you can not get into trouble. But I am having a hard time coming up with a scenario where a walking beam is worse than a regular trailer as long as you remain within the weight limits of the trailers.
Ken
/ Walking Beam Trailer #22
I bought a MUTS with mesh wall extensions (MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler) last fall and have been using it to haul (mostly) horse bedding/manure so far. I also plan on doing some work in the woods with it this summer. It hauls very nicely behind my RTV 1100 without cutting the corners excessively on turns; it hardly notices bumps in the path.
I had lobbied my wife for a hydraulic dumper, but the cost was about three times the MUTS (though with twice the rated capacity, or so). Cranking the winch on the MUTS to dump hasn't been as much of a pain as I thought it would be, even when the saturated bedding/manure is piled right up to the top of the side extensions.
The DR-Versa and T-Rex are similar so I presume they'd perform as well as the MUTS.
/ Walking Beam Trailer #23
Could you mount a 12v Winch to Do the Cranking? Deff cheaper than Hydraulics
/ Walking Beam Trailer #24
I don't know anything about walking beam trailers or hauling logs, but what does it matter what terrain the trailer can go over if it's too rough for the ATV with minimal suspension travel to traverse?
I'm slowly coming around to recognizing that point. In my original post I was envisioning a super-trailer that could haul more than my UTV can safely tow and could traverse terrain much more rugged than my UTV can navigate. Given that most of the riding I anticipate will be on trails or trail-like terrain, a less capable off-the-shelf trailer may be more than adequate for my actual needs.
/ Walking Beam Trailer #26
I thought of this, too, but after a few months of using the trailer, I am pretty comfortable with hand-cranking it (somewhat to my surprise!). In a few years, when I'm in my mid-70's, I may change my mind; later conversion to electric winch is always a possibility.
/ Walking Beam Trailer #27
/ Walking Beam Trailer #28
I guess maybe i'm just accident prone....but then when you just "sit in a chair all day", not much chance of getting hurt.....I'm a Do'er and Do'ers get abused.
As a truck driver, I Hand Crank trailers up and down. Had one going up hard one time, the handle came out of gear. So now I'm cranking hard and now it's free.....my hands spun around and came up under my chin.....I woke up wondering "What the Heck just Happened"...lol...oh wait..no it wasn't LOL...lol
/ Walking Beam Trailer #29
I looked at the "muts"trailer, and there is a deal breaker fault for me. The wheels are too close togather. When clay sticks the the wheels they will bind up and on hill tracks, will drag you to a halt. Been there didn't like that at all. The wheels need 6-8" between them to beat the increase in diameter caused by clay.
The rest how ever looks good. I would probably fit a false floor and use it to feed out hay (conventional bales), it should fit 12 in 3 layers @ 6' long. Should carry a good load of firewood to.
/ Walking Beam Trailer #30
Are you sure you want a walking beam ? Single axle would support a ton also, with similar sized tires, and because you dont need swing travel you can maintain loading height with slightly bigger tires. It will drag less in tight corners.
Also, make it at least 2 ton if it is the only trailer you have. When you need to transport a 2 ton object, you will use what you have...
/ Walking Beam Trailer #31
I've been looking at some trailers for off-road use and am contemplating building my own. There are some mighty fine examples in some older threads, and I'll shamelessly steal all the good ideas from those. :)
The trailer available from DR and Woodland Mills is pretty much what I want. I'm exploring a design for something a little heaver duty and sized for my needs.
What are my needs? Something I can haul with my Arctic Cat Prowler (tow limit 1500 lbs) as well as my LS XJ2025 tractor. I want it to have a tire width the same as the Prowler, and am looking at a walking beam design to allow for taking it over some rough terrain. I'd like to be able to tow it with the tractor with upwards of 2,000 lbs in materials.
My first effort in Sketchup is here:
And here's what I've got for a walking beam. I'd like to have 360 degree rotation for the walking beam, for when I'm in the really nasty stuff.
In addition to the reasons above for building my own, I live in Alaska and freight shipping of big items is brutal. I'm guessing the freight for the $1500 Woodland Mills unit will be another $600 or more. So I could potentially get a better trailer for less out-of-pocket expense.
My initial design uses 3x2 rectangular tube (1/8" wall) for the main elements. I experiments with the StructuralWeb beam calculator and determined that the walking beams would have no problem supporting a ton of cargo. My concern is the center beam for the frame. I'm pretty sure that I would get a lot of deflection on the tongue. Anyone have suggestions on what an optimal tongue beam would be?
I think you are over building your trailer. Steel is extremely strong and durable. Also heavy. The goal is to minimize trailer weight and maximize capacity.
Look at how light weight boat trailers are made. They are very strong yet light. Remember if the box dumps it also must have a frame. The weight adds up quick. An ATV can be quickly overloaded by an over built trailer.
Again study the MUTS trailer and how it's built. Very elegant design. Tongue weight is only around 30 lbs.
/ Walking Beam Trailer #32
Hang on to the MUTS crank handle and you will be fine. The handwinch works great and requires no wires or power.
/ Walking Beam Trailer #33
Fortunately for me, my neighbor, I call him McGyevor, just tell him what you want and he can build it. He made a pull around backhoe, put a loader on his garden tractor, a dump bed on his nissan....
And that crank handle was on a 6500 gal tank trailer, loaded...
/ Walking Beam Trailer #34
Yeah those heavy trailer cranks can be bad business. The little one on the MUTS trailer is not as dangerous. The 6500 gal tank trailer is a whole different story! Yikes!
/ Walking Beam Trailer #35
Around here I often come across old single axle leaf spring trailers, usually for free. Other than the axle under the trailer they are simple and easy to turn into an ATV/ UTV trailer. I'm currently building a 54" x 68" trailer to pull behind my UTV. I was given two trailers, a single place snow machine trailer and a Holsclaw boat trailer a couple years ago. Last year I got some golf cart tires/ wheels (which are the standard 4 on 4 lug nut pattern). I over built the steel frame by using 2"x3" 1/8" tube but it's not too heavy and it'll last for ever.
Not knowing what you can find second hand it's hard to offer advice but I would try to get a used axle and leaf springs if possible. Ideally two axles rated for around 1500 lbs each and connect them with equalizers. If you have a golf course near by you may find some tires for a reasonable price. I think the golf cart tires are rated for roughly 1000 lbs each. I made one trailer dump but found it was more trouble than it was worth. The weight always seamed like it was either too far back or too far forward to easily dump. Plus I like to make them low enough to get firewood into the trailer with a minimal amount of lifting.
/ Walking Beam Trailer #36
Here is the link to my thread. http://www.tractorbynet.com/forums/build-yourself/204019-my-version-kk-xb-dump.html?highlight= I built a walking beam axle trailer in 2011 and use it almost daily. It is very long and I had many questions that were answered by many more knowledgeable than I! It has many pictures from the build to paint. I think it is worth the read. I love the walking beam axle and the one thing I would do differently now (almost 6 years later) is put stops on the beam to keep it from hitting the bottom of the bed when it "walks"
/ Walking Beam Trailer #37
Heres an idea for the walking beam. Mount a regular trailer axle to your frame and use that as the main axle for the walking beam. Gives you good bearings and easy to get parts. Then just figure out how to bolt the walking beam to the trailer tire studs
/ Walking Beam Trailer #38
Use the axle and bearings but instead of a hub, have a piece of tubing machined out on the insides to accept the bearing races and seals.
/ Walking Beam Trailer #39
Or make a plate with the hub and stud spacing. Or cut up and reinforce an old wheel.
/ Walking Beam Trailer #40
You will love the walking beam. I have one of the DR versa trailers and it walks over almost anything. Also I like the ground clearance between the tires. Mine was second hand but barely used, $600. Odd looking but works well. Jim
John Deere S350 (A60462)
John Deere S350...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRACTOR TRUCK (A59912)
2019 INTERNATIONAL...
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2004 John Deere 8320 (A63688)
2004 John Deere...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
