Franken-ballast: expensive and poorly planned!
/ Franken-ballast: expensive and poorly planned! #21
So when i use my box scrapper or any ground engaging equipment thats on the ground an providing zero normal force on the rear tires. The 2000lbs of juice added to the tires adds a fair amount of tractive effort allowing me to pull tje 1400lb box scrapper with the shanks down through clay without spinning out constantly. My tractor is a tractor ive never thought about taking the weight out of the tires.
Tire ballast has its purpose its not the optimal ballast loader work though
Yep. I won't give up my rear tire ballast. Also allows me to do 90% of my FEL work regardless what's on the 3pt.
/ Franken-ballast: expensive and poorly planned! #22
That turned out great Luke. Makes me want to cover up my concrete and steel weight with a tarp so I don't have to look at it anymore.
Do your tool holder tubes have weep holes or caps?
If you mean at the bottom, then yes and then some. There is a 3/8" hole for water and dirt. I have a "probe" to clear it out if needs be so that I will rarely have to turn it over.
Thanks everyone!
/ Franken-ballast: expensive and poorly planned! #25
Very nice, perfect for use with FEL in tight quarters
Exactly, I can't imaging doing 75% of my tasks with a box blade or rotary cutter as ballast. No way. No how.
/ Franken-ballast: expensive and poorly planned! #27
Yeah, me neither.
The Franken-ballast has been working great.
Yesterday I was using it to move my 25ft gooseneck equipment trailer. Went to set it down and the ball wouldn't disengage like usual. Found out why....
This scary cold weld was part of the original Countyline trailer mover I built around. I know this was designed for low speed but still seems dangerous as heck.
I ground down and rewelded the nut.
/ Franken-ballast: expensive and poorly planned! #29
Yikes!
Low speed failure might be okay sometimes, but doesn't matter if you're on unleveled ground and the trailer decides it wants to climb up with you into the tractor seat.
Yup. And I never use safety chains with the tractor... This SHOULD be a learning experience.
/ Franken-ballast: expensive and poorly planned! #31
I'd be way more worried about the trailer getting in the seat with me and the chains are too long to prevent that.
Good point. That's enough to justify my intention to continue to disregard the chains. :laughing:
/ Franken-ballast: expensive and poorly planned! #33
Mind did the same thing if not slightly worse. 7 yards of dirt in my dump trailer behind a 100 hp Deere. Wrecked all the treated and broke the bolt. Going to weld a piece of 3/4" plate where the nut was, blow out a hole and weld the ball solid.
Good looking weight rack
Brett
Ya, that nut is going nowhere now! Lol.
Hope you didn't loose the trailer. That's a lot of unsupervised weight!
/ Franken-ballast: expensive and poorly planned! #35
FWIW,
If you build your own ballast, have a plan for when you tip it over by accident and have to stand it up and maneuver it to where you can hitch up again. I did this just this weekend and the hitch receiver was useful for chaining up to the loader arms and moving it very carefully (not much weight on the rear end). If I had planned for this, I might have done things slightly differently (like mounted d-rings on each side or something like that).
/ Franken-ballast: expensive and poorly planned! #36
FWIW,
When I built my ballast barrel, I left a piece of 2"x2" 3/16" angle sticking out of the top with a hole in it for a clevis to attach. That way, I have a good lifting point at the top of the barrel.
Aaron Z
FWIW,
Yup, the skids on the bottom of mine got about 9" longer the first week. Guess why? :D :drink:
/ Franken-ballast: expensive and poorly planned! #38
Welded the snot out of the country line carry all I bought. Good idea to add weld to most of their products.
/ Franken-ballast: expensive and poorly planned! #39
Were I to do it all over again, I would put steel (maybe not welded though) from the back edge of the carryall up to the top-link. That top link cross bar on mine is bending slightly. It takes more of a pounding than I though.
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Utility Cart (A59231)
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
