OP
Lineman North Florida
Elite Member
- Joined
- May 12, 2008
- Messages
- 2,866
- Location
- LaCrosse Florida
- Tractor
- Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I could probably rig another spacer and take a disc off but this is an offset harrow with 24" notched disc blades and I think rather than start jabbo rigging on a new harrow I'll just go with the 8'9" disc that weighs 2800 lbs and that way I shouldn't max out my tractor either, I already have a Bush Hog model 1432 10' leveling harrow that I completely rebuilt last year with all new bearings and 22' disc blades, but I have no idea what it weighs.If you go with the larger disk and it proves to be too large could you drop a blade off of each axle? If so and it would work fine I would go with the larger disk. I have a 10 foot wide tandem disk with smaller blades and can pull it fine with M6800 2 wheel drive decently. I can really handle it with my 5525 four wheel drive JD with about 74 or so draw bar hp. Not sure if my blades are 20 or 22 right off.
