Wet stacking generators
   / Wet stacking generators #11
You've got a newer unit. It might have better controlled electrical output than mine does. And you're running through a transformer. I'm patching into my service panel using a simple interlock: that's the plan- I'm all wired up; have not changed wiring on generator yet (have a receptacle plug due in shortly).
It is claimed that no one is aware of the generator head on the generator that I have ever going bad. Trade-off, I'm thinking, is that the power isn't as clean as newer units. Here's a link to a thread I put up on SmokStak. And this is my only reservation.
   / Wet stacking generators #12
I'm learning about this stuff as I go. I thought the VR was something magic (for Onan prices it should be) and have a spare VR for my 7.5. I got a 12.5 Onan/Isuzu awhile ago and opted not to use the Onan computer/VR. I just bought a used, universal Basler VR! Works great.
I don't know where your ugly power could be coming from. I do think, some of the cheaper alternators have more harmonic distortion although I'm not going to pretend to understand this. Every one of my units is brushed, so that isn't a concern for power quality.
I had a friend who once had a brushless Winpower (I believe) 20KW set behind his Ford 5610. His lights flickered like crazy. I had to laugh (to myself) as the man was so wealthy, and yet had such crappy power. I thought it was on account of a pretty crooked driveline but he insisted not. I never did find out what it was.
As far as a transfer switch. Hey, at least you have connectors. I used to throw the main switch and clip booster type clamps into the splitter box.
   / Wet stacking generators #14
NICE. That's what I like to see. Who makes the alternators? I notice they use the Dynagen controllers. I have a couple I have been meaning to install.
Surprised they use Paul SR for advertising. Apparently a fraudster and in some financial trouble. They even dragged poor little innocent Mikey into it!
   / Wet stacking generators #15
I had a friend who once had a brushless Windpower (I believe)20KW set behind his Ford 5610. His lights flickered like crazy. I had to laugh (to myself) as the man was so wealthy, and yet had such crappy power. I thought it
LOL, yeah, Onan/Cumins prices ARE up there! I'm in need of tracking down a coolant sensor (torn between going through the hassle of taking it out and matching it up or just ordering one up).
I think that I'd read about the replacement VRs. I'm only proficient enough in this generator-speak to say that I recognize those two letters together:D No clue whether that applies to my genset or not.
bdog, just keep in mind all the other costs associated with plumbing up a generator. I went out on a limb and shelled out $2,500 for my 1993 unit. For me, I view this all as for emergency situations only: my wife is really good at dealing with lower-level living, so managing lower-down on the convenience scale is doable (so that has, in theory, saved us money)- it'll be all-manual (though there IS electric start on the generator).
   / Wet stacking generators #16
Buy the larger 10 instead of the 8, even if you don't need it, (one day you will) depending on the design of the alternator, if your prime mover has more power than the rating of the alternator, the alternator can be overloaded and the engine keeps powering it and the alternator eventually burns out. If the engine is less powerful than the generator then when you try to overload the the alternator the engine bogs and can't produce the power so the engine feels it but the alternator can't overload and burn out.
At $380 more for the heavier alternator with the same prime mover, I would go the 10. YMMV
   / Wet stacking generators #17
Those are pretty good prices for the size in brand new. Looks like enclosures are kind of pricey but you could probably build your own enclosure.
I purchased a 10KW Tactical Quiet surplus generator this year. Wet stacking is a common discussion over on the Steel Soldiers Forum. Mine has 2600 hrs on it and no sign of wet stacking. I have only used it for 4 hours but I test run every month with a 40 amp load. When I actually used the unit for 4 hours it didn't see much time near the 40 amp load I test under. I think it got up to 32 with the AC, well and rest of the house running but I turned off the hot water heater and some other stuff to manage load.
Either way you will probably want a load bank to test run and exercise the unit. Here is a thread on the one I made to run mine.
   / Wet stacking generators #18
I think the recommendation is to run once a month (or a frequent run) without* a load and to do a full-over switch quarterly. That's my plan. Doing a full switch over ensures that the entire system is able to do what it's supposed to do.
* For sure, if you can load it then do it. But, it's not necessary for brief/operational checks.
   / Wet stacking generators #19
Wet stacking is a real problem. But NOT in yours. You have small units that will have load on/off of them, that will cure the problem. All will get warm enough.
As for your salesman, he is just that, a salesman. He wants you to purchase some sort of load bank thus increasing his profit.
Given those conditions, and the size of your units, you can skip the load bank.
George
My current generator is a military mep003A 10kw diesel. It has worked well but the frequency varies more than I like for the computers and it is super loud. I am not using this for my house it is strictly to power a mobile office type trailer. I often set my unit up fairly close to people's houses and the noise makes them mad. I thought about the tactical quiet but I think all the military units have manual frequency control. These other units are computer controlled frequency and voltage.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
DEUTZ MARATHON...
More info coming soon! (A56858)
More info coming...
