Walking Beam Trailer
/ Walking Beam Trailer #1
ChugiakTinkerer
Chugiak, Alaska
LS XJ2025H
I've been looking at some trailers for off-road use and am contemplating building my own. There are some mighty fine examples in some older threads, and I'll shamelessly steal all the good ideas from those. :)
The trailer available from DR and Woodland Mills is pretty much what I want. I'm exploring a design for something a little heaver duty and sized for my needs.
What are my needs? Something I can haul with my Arctic Cat Prowler (tow limit 1500 lbs) as well as my LS XJ2025 tractor. I want it to have a tire width the same as the Prowler, and am looking at a walking beam design to allow for taking it over some rough terrain. I'd like to be able to tow it with the tractor with upwards of 2,000 lbs in materials.
My first effort in Sketchup is here:
And here's what I've got for a walking beam. I'd like to have 360 degree rotation for the walking beam, for when I'm in the really nasty stuff.
In addition to the reasons above for building my own, I live in Alaska and freight shipping of big items is brutal. I'm guessing the freight for the $1500 Woodland Mills unit will be another $600 or more. So I could potentially get a better trailer for less out-of-pocket expense.
My initial design uses 3x2 rectangular tube (1/8" wall) for the main elements. I experiments with the StructuralWeb beam calculator and determined that the walking beams would have no problem supporting a ton of cargo. My concern is the center beam for the frame. I'm pretty sure that I would get a lot of deflection on the tongue. Anyone have suggestions on what an optimal tongue beam would be?
/ Walking Beam Trailer #2
Keep the same material, but put a truss on the tongue. Much like a engine hoist has one on top, put yours on the bottom of the tongue to support excess downward force on the tongue.
Or, keep the same material, but put another piece along side the original center tongue piece. In other words, double it up. Stitch weld it the full length top and bottom. Double it up the full length, from the tip of the tongue all the way to the rear. Make your other crossmembers shorter to compensate.
/ Walking Beam Trailer #3
I think you beam trunion is too short and will twist. Consider having the shaft be full width with a pair of pillow bearings on either side.
/ Walking Beam Trailer #4
have seen a few trailer tongues were they just tac welded flat bar to sides/top/bottom. of the longer tongue. same concept of what franklin2 talking about. but more likely more geared towards 'torque' / twisting the tongue vs. causing the tongue to bend. in essence making the tongue portion a thicker wall .
the pieces you have dropping down for the rotation of beam/wheel. see about running axle all the way across for the beam/axle rotation. so the axle itself becomes a support brace per say. to keep the wheels/beams from angling/bending out.
looking at the 2 trailers you posted links to. the single central beam structure. looks rather nice, and looks like everything slides onto central beam then bolts/pins to central beam to keep it in place. vs welding everything to the central beam. assuming part of this is for perhaps packaging everything and tossing on a pallet then assembly were ever. but looks from pictures, the slide bolt/pin combo would allow you to adjust things.
if you are not going with central beam thing. i am then wondering why do you need a central support running all the way to the back? ya part for tongue. but all the way to the back?
/ Walking Beam Trailer #5
Those short sections of box supporting your beam pivots will fold flat in no time without some sort of additional bracing (internal web, cap the ends, gusset up to crossbar, etc. etc.). That's probably going to be you single highest stress point in the whole structure. I realize this is just a concept sketch, but that point needs a bunch more attention.
Take a look at this pic fomr someone else's thread:
http://www.tractorbynet.com/forums/...-convert-air-brake-equipment-trailer-sub1-jpg
and look at how much structure they have around their pivots. Their loading is different because they are supporting both sides of the beam, and I understand why you don't want to do that. The other commenter's idea of continuing your beam pivots across the trailer as a single piece (or welded to a single piece if that long a piece of round is hard to get) is a good one, it gives your pivots a much longer lever arm to resist twisting the structure.
Speaking of twisting...have you looked at what a ton load will do to twist your walking beams between center and end, not just the simple beam bending end-to-end? You will basically have a twist with 1/4 ton times the distance from the beam to the center of the tire (maybe a foot?), so 500 ft-lbs, before you even start getting into multipliers for shock loading from hitting stumps, etc. I'm not saying you are wrong that it will be OK, I am just saying run the numbers and see.
Thanks everyone for the feedback. I'm a monkey-see, monkey-do sort of builder so I am a babe in the woods when it comes to knowing whether or not my proposed structure is adequate. So please keep up with the suggestions and comments.
That may be why I see so many of the dropped tongue hitches - not so much because the height is an issue but to allow for gussets. Hmmm...
Thanks, I should have mentioned that this is a conceptual design, not at all final. I plan on making the trunion connection more substantial.
One of the up sides of not having a continuous axle is the increase in ground clearance under the trailer. My first instinct is to think I don't want an axle going all the way across but I should know by now that my instincts are not always right. :laughing: It's definitely worth looking at your suggestion, or some variation thereof.
The short box is just a spacer for me conceptually. I would at the very least have it with a 45 degree cut tapering down and weld on a plate at each end to give it support. The stub axle would probably be a square end like this guy ( Spindle 1-1/2" Square x 4" Long Stub, for 2, lb. Trailer Axles Redline Trailer Spindles SP24BT8 ) to facilitate welding. Or something completely different - way out of my league here and open to suggestions.
As noted above I need to do some more work on my mock-up to reflect where I think I want to be. A brace angled up from the axle stub to the frame above would strengthen things pretty well without bringing an axle into the picture. Should still allow good clearance of brush and tussocks.
Regarding the trailer I linked to, I am thinking of something comparable from a performance standpoint, rather than actually riffing off the design. Doesn't mean I shouldn't borrow a good idea. I'll chew on their design a bit, but I think you are right that it's made that way because it gets shipped as a kit. Not necessarily a bad thing, I can see that an adjustable trailer length could be quite handy.
/ Walking Beam Trailer #9
*rubs chin* you noted clearance underneath and not wanting an axle all the way through to each side. but for me. only time something like that has become an issue. is when i sunk everything into a wet spot in hill side, that i did not know was there. and i was already past my axle point if not deeper in the mud. granted your in alaska and riding on top of snow itself is beyond my knowledge. but even with snow here in Illinois. i would end up getting stuck with pulling vehicle first, before ever worrying about trailer tires getting stuck. in my instances it would be going through 2 to 3 feet or deeper snow drifts trying to clear the driveway.
i have more issue rolling over logs with tractor / truck / even an ATV clear back in the days. the pulling unit needs to get over them logs as well. granted... with tractors and field implements. some of the larger field stuff have "trip wheels" something like if not the same walking beam idea. so when trash (dirt, corn stalks, etc...) pile up, the wheels will rotate over the trash pile and continue going vs raising up the implement from the ground. but with field implements the tractor is not rolling over piles of stuff, the piles of stuff are happening due to ground engagement and tearing up the field and causing the piles to be created between pulling unit and the trip wheels / roll over wheels / beam wheel setup.
i realize there are some folks that run ATV's and hip/hop over logs on there trips out into the forest to have fun. and i could see the walk beam / wheels being a benefit to those folks possibly. but i am guessing those folks more out there just running there 4 wheelers / ATV having fun, jumping around, taking sharp corners, spinning tires, trying to take steepest incline they can take, etc... maybe you are this person.
if you were planning on smaller diameter tires vs a single larger tire diameter. i might see walk beam / wheels as something.
ya trying to talk ya out of the walking beam/wheel design. good old leaf spring axle setup been around for ages.
with above said. sounds like ya got a plan down and finding your parts already to see the idea through *thumps up*
/ Walking Beam Trailer #10
You might want to look at Torsion Axles.
They mount to the frame so there is no drop down but you have the strength going all the way across.
Hehe, I guess you guys are starting to talk me out of the walking beam. The more I ponder things the more I realize that what I want would probably be too heavy to haul with the UTV. And that's really I what I need, not a trailer for the tractor. I'm still very much interested in tandem axles, maybe of the more traditional variety. The reality is I am probably not going to tow this trailer across the wilds of Alaska. I'll cut a trail through some woods and use it to haul stuff to my property. With a modicum of trail maintenance I shouldn't be in a situation where I need a 360 degree walking beam.
I'll do some more reading and head-scratching this weekend and see where I end up. There is a nice ATV Wagon on my local Craigslist at a good price, but I'd rather have something that I can haul logs and long lumber with. Maybe I ought to at least get a shipping quote on that Woodland Mills, so I know what to compare to.
/ Walking Beam Trailer #12
This modified AgriFab trailer works fine behind mt ATV, my Tractor, or my small hay wagon being pulled by my tractor. I just replaced the axle with a longer one and added some spacers. Not sure why they did not make it a walking beam to begin with. They were so close to what was needed. I have used it for 10 years now. Works great. I fill it overflowing with firewood.
Ken
/ Walking Beam Trailer #13
talk you out of it, and now talking you back into it!
i am sorry about that. you can tell how long since i drove a 4 wheeler/atv.
http://www.apriliaforum.com/forums/showthread.php?235487-ATV-versus-UTV-for-logging 3rd picture. i forgot about wanting to keep all 4 tires of a tanduem axle trailer on ground. so use to pulling regular trailers. that me forget, when you go into ditches, streams, etc... good chance only 2 tires touch ground, vs walking beam design were all 4 tires stay in contact with the ground. like you noted not full 360 degree.
ATV trailer. tandem/walking axles
Swivel trailer hitch for ATV?
http://www.tractorbynet.com/forums/customization/338280-atv-trailer-post4157308.html#post4157308 = 2nd picture of post 13
http://www.hondaforeman.com/attachm...338694645-homemade-atv-trailer-0217121624.jpg
short quick video putting trailer together.
http://www.countrymfg.com/atvwagons.htm = this is what i am use to see'ing hay wagon, but smaller for ATV. were everything pivots at the tongue. vs wheels / walk beam design.
I watched the video on the Woodland Mills web site and am thinking maybe I should just go with the off-the-shelf solution. I want to be able to haul logs and lumber and that rig looks like a great way to do it. I have a Woodland Mills sawmill and am impressed so far with the customer attention the company provides.
/ Walking Beam Trailer #15
You will need a diagonal brace on the walking beam pivot mount bracket or the whole lot will splay out.
2nd point, which noone has mentioned, make sure you have reasonable (6"-8") clearance between the wheels. On an old walking beam trailer I had the mud would build up between the wheels and drag the trailer to a halt. The atv ran out of traction, not power.
3rd, larger wheels roll over mud better than small.
Good luck
/ Walking Beam Trailer #17
FWIW, I'm at an auction today with a nice provenost trailer. This is the walking beam... IMG_20170429_085435153-2254x4007.jpg
/ Walking Beam Trailer #18
^^ That's a decent design. I'd suggest not worrying about letting the beam go 360, and just make sure it has decent travel. It's going to upset the trailer more if it "trips" and goes 360 than if it is forced to go up and over.
Torsion axles are good for clearance. Bad for ride, IMO. They have very little actual suspension travel, and it sounds like the OP is looking for is a way to "average" out the terrain. The walking beam design does a great job of that! (Any obstacle only "bumps" the trailer by half the obstacle height.)
We have a little Yutrax trailer that has two wheels. It bounces all over behind the four wheeler if you go faster over rough ground, but has been fine for clearing slash. It's not a really heavy use trailer, but they do offer a walking beam version, and watching the vids, it is obvious that it rides MUCH better than the 2 wheeled version that we have. BTW, the Yutrax tows much better now that I welded the 3pc to 1pc. :)
As someone who builds almost everything I need, I'd say you're not too far off with your trailer. Get the beams under the side frame to take some stress off the pivot, and provide a reasonable travel stop. Then widen out the frame to get the track width back to where you want it. (More cargo area!!) I think 2x3 1/8" wall would be fine for the majority of the frame, but I'd up the tongue to 3x3 1/8", as the tongue will not only see vertical loads, but also side to side, especially over rough terrain. If you think you'll really load it heavy at times, you could even go to 3x3x3/16" on the tongue, and never worry about it.
FWIW, the Yutrax uses the same spindle for the walking beam pivot that they mount the wheels to. It rides on two wide roller bearings. I think you could honestly use some cold rolled round for the axle, and DOM for the pivot tube, and just put a grease fitting on it and it'd be fine. Then weld trailer stubs to the beam, and mount up tires of your choice. :)
And do share some pics when you get the build going!!
/ Walking Beam Trailer #19
I do not understand that statement. For me, the beam only rotates when the front wheel enters something deep and steep like a ditch. Under that circumstance, the rotation makes the trailer go very smoothly through the ditch. I have yet to try to go over a log so tall that the beam would want to rotate. I think my trailer would be bottoming out under that scenario. If there were a tall narrow rock for example (which i would not have on my trails), then it may want to rotate.
The Woodland Mills trailer looks very nice. I have looked at it online several times. If I had no trailers already, I would be tempted.
Ken
/ Walking Beam Trailer #20
[[ i realize there are some folks that run ATV's and hip/hop over logs on there trips out into the forest to have fun. ]]
These are the guys that keep our Emergency response numbers so high....
I'm picturing him getting it hung up and then wanting to be able to "Roll" the hung side up side over say, a rock or stump..I'd think the back wheel would have to be higher than the front wheel to get them to "Roll" on the Axle..My fear is that, now, that side would rise making that side closer to a "Rolling Over" point
2022 Kubota MX5400 (A60462)
2022 Kubota MX5400...
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
Trimble Guidance System (A60462)
Trimble Guidance...
YARD MULE (INOPERABLE) (A60736)
YARD MULE...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
