Kubota Bx1800 weird HST problem
/ Kubota Bx1800 weird HST problem #1
7fayette
Memphis
bx1800
My Bx1800 has a weird problem the dealer has put 40 hours of wrenching time into it and has no idea what is wrong. When the pto is off the tractor does not have any hydraulic pressure causing the hst to make a grinding sound in forward and reverse. It does not matter if it is in high or low. When this happens the tractor has no power and hardly moves, but if you turn on the pto it runs just fine. Dealer has been scratching their heads over this one. Dealer says the pump has a little wear on it, but nothing critical. Thinks it might be the clutch pack. Any ideas?
/ Kubota Bx1800 weird HST problem #2
Hydraulic pump goes to steering priority valve, until required flow for steering is met nothing goes to loader or back to tank. Next is the steering valve, then it goes to PTO valve and PTO relief valve teed together. PTO relief valve dumps into hydro filter and then that flow goes to the hydrostatic transmission for charge purposes.
Sounds like the transmission is not getting charge pressure fluid and the tranny is running dry. Someplace between the steering valve and the PTO valve/PTO relief valve the fluid is getting dumped but the PTO activation is plugging the leak to build up enough pressure to charge the transmission.
Is the correct hydro filter on?
Is there enough flow from pump?
Just some ideas, oil flow chart in on page 2-M5 in BX WSM manual
David
David
Could the pto shift valve be out of alignment? meaning it is aligned when the pto is turned on, but slightly out of alignment when off causing the dump in pressure?
/ Kubota Bx1800 weird HST problem #4
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2016 Ram 5500 Flat Bed (A63689)
2016 Ram 5500 Flat...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59914)
2025 ALCOM XPRESS...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
