Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,201
Here is my front mounted rake contraption. I actually use it more often with the rake tines turned inward so I rake while backing up and spread dirt driving forwards. I would give it a C minus overall but it does come in handy at times. Best part is being able to see exactly where the rake is when maneuvering close to the house etc.
I have one of the front mount "rake contraptions" but haven't used it for my rake yet, used for snow plow that way I have an easy on easy off plow to bucket if needed. Going to try with rake now
Sent from my iPad using TractorByNet
/ Grappling fun - A Picture Thread.... #1,202
It looks great!
Even better, I'm guessing it weighs less than your bucket by quite a bit!! :cool2:
Travis
Seems lighter but really helps getting the load so close to the pins. I haven't been able to bend it yet and I have been really beating on it. Another great feature is using it to get unstuck just plant the closed grapple against the ground or stump your next to and open it and the hydraulics have plenty of power to push you back to get unstuck in the soft ground.
/ Grappling fun - A Picture Thread.... #1,203
Loving my new 55" EA Wicked root rake grapple. Moving one of my big brush piles out of my field. Love the clamping force and versatility of it. Works great for picking up logs, brush and stumps been ripping out a bunch of alder stumps with the nice soft ground. Yes I know the ROPS is not all the way up, only way it will fit in my shed. I do have loaded rears and my ballast barrel on though. :)
View attachment 507312 View attachment 507313 View attachment 507314
Looks like you're getting some pretty big bites with that rake style grapple.
/ Grappling fun - A Picture Thread.... #1,204
Great for brush and other compressible stuff, just don't try to pick up two or three logs or rocks at once. The clamshell hinge will jamb on the first and nothing else will be clamped. Same issue as with 4n1 buckets.
/ Grappling fun - A Picture Thread.... #1,205
If only it was wider and had two lids... :D
/ Grappling fun - A Picture Thread.... #1,206
No worries about multiple rocks with my small tractor. I was able to pick up multiple logs no problem, you have to come down on them from the top and clamp them then rotate back the bucket once you have them. Just unloaded a bunch of 6x6 timbers from my trailer and was able to pick 3 off the top row from above no problem, would be a huge pain with a standard grapple and having them hanging out that far, even if I could get my loader up high enough.
/ Grappling fun - A Picture Thread.... #1,207
Oh oh Luke! I hear them coming!
/ Grappling fun - A Picture Thread.... #1,210
Very cool rake set up and great view!
/ Grappling fun - A Picture Thread.... #1,211
75 hp and 4WD handles this 5' LR easily!! :laughing:
/ Grappling fun - A Picture Thread.... #1,212
/ Grappling fun - A Picture Thread.... #1,215
That was near max lift on the tractor. I have a set of pallet forks with a clamp on the CTL , but the grapple is better.
/ Grappling fun - A Picture Thread.... #1,217
Wasn't the smoothest installation.... had to grind down some welds that were interfering with my quick hitch and the hydraulic fittings were loose and dumped almost my entire tank of fluid, but great once I got it installed... first job with my EA BX grapple. 8974A5D3-9B9A-492C-8A23-B4B86706B6FD.JPG
/ Grappling fun - A Picture Thread.... #1,219
Wasn't the smoothest installation.... had to grind down some welds that were interfering with my quick hitch and the hydraulic fittings were loose and dumped almost my entire tank of fluid, but great once I got it installed... first job with my EA BX grapple. View attachment 507765
I am confused, this is a quick hitch, it goes on the back:
Quick attach goes on the front.
Does yours look like this?
/ Grappling fun - A Picture Thread.... #1,220
OMG, this is the first time in TBN history that a noobie confused quick hitch with quick attach!!!:D
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
