2210 PTO Issue
/ 2210 PTO Issue #1
Hambone
Southeast Kentucky
JD3032
Ok guys. I've read a lot of the 2210 threads on broken gears and carnage. I was tilling, I hit a rock, slip clutch slipped like it was supposed to. I got Rock out and restarted. Went about 6 more feet and PTO stopped working. I figured for sure it was bad.
I checked all the fuses, all good, Checked the switch, it was working. Checked PTO solenoid and had power there. Pulled solenoid out and didn't see any issues. Energized solenoid out of tractor and it pulls valve just like it should.
So after all that I was hanging my head low knowing the rear gears/housing was broke.
Pulled the rear cover off, all the gears and housing are good. Both shafts spin well, shifter moves well from mid to rear PTO.
I am out of options. Any ideas?
/ 2210 PTO Issue #2
So it won't come on at all now? Anything else happen that you might have left out?
/ 2210 PTO Issue
The tilling was pretty rough, but slip clutch slipped like it was supposed to.
When you have mid Mount selected, rear shaft turns nice, same when you select rear, the mid turns good.
Oil looks good, removed filters and no debris in there either. IMG_20170417_1952593.jpgIMG_20170417_1952593.jpg
/ 2210 PTO Issue #4
So absolutely nothing happens when you engage the PTO? Does the PTO shaft spin free when the PTO is disengaged? My 4400 has a brake so you can't turn the PTO shaft when it's turned off...not sure if a 2210 is similar.
/ 2210 PTO Issue #5
That's weird it's doing that. I can do some looking tomorrow at work and let you know if I find anything.
/ 2210 PTO Issue
If you select Mid mount PTO, it will not spin but the rear one does, if you select rear PTO it wont spin but then the mid does.
When it is running it doesn't make any noises, nothing unusual. The FEL and 3 pt hitch, along with power steering all work normal.
It didn't make any noise when it stopped working either.
/ 2210 PTO Issue
I ordered a new gasket and solenoid. Just because I can energize on the bench, doesn't mean it will actually work under hydraulic pressure.
While I was on the phone I ordered a new seat, after all it is 14 years old and the only thing I have done is put on a new belt for the deck. After 720 hours, I guess I can do that and feel okay about it.
I will keep y'all informed.
/ 2210 PTO Issue
Got everything back together with new solenoid. Still no PTO.
Any ideas?
/ 2210 PTO Issue
Ok boys and girls. I thought I would share what the outcome was since I just got it back and going Friday.
The snap ring on the PTO clutch pack failed and the clutches came out of the drum.
It didn't tear much up, needed a piston and snap ring. $1000 labor and she is good as new, well as good as 720 hours anyway.
Thanks for your input
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
2002 Generac SG0035 43kVA Natural Gas Generator (A66734)
2002 Generac...
1997 Load Trail 8'x20' Gooseneck Trailer (A64912)
1997 Load Trail...
2017 John Deere XUV825M S4 (A64912)
2017 John Deere...
