Is this the law
/ Is this the law #1
sam5570
south west virginia
new holland tn70
Well a friend call me and said you not gonna believe what happen to me today.I was pulled over by the state police and he gave me a ticket that carries a fine up to 10,000 dollars. He was pulling a trailer with equipment on a trailer dull wheel pick up and they wrote him a ticket for not having a medical card because his total weight was over 10,001 lb. I never heard of this have you?
/ Is this the law #2
"total weight" ..... on the trailer?? ..... "was over 10,001 lb."?
Was the combined GVWR over 26,001 lbs.?
/ Is this the law #3
I would go to your states website.
Without telling us your state, it is even more of a guess, than what you would normally get.
But the cop did write the ticket, he is probably more familar with that states laws than me.
/ Is this the law #6
OP says:
Location south west virginia
https://www.dmv.virginia.gov/webdoc/pdf/dmv60.pdf
Bruce
/ Is this the law
no I have had a CDL for many years and am aware of the weight limits. the reason I didn't put the state was the trooper said it was a federal law that if you transported anything with a combined weight over 10.000 lb you were required to have a medical card.
/ Is this the law #9
>10,001 combined weight? That's nothing more than a well stacked load of wood in the bed of the pick-up or towing the boat with gear with a full tank of fuel and two passengers to the lake. Not knowing for certain but thinking (at least hoping) that can't be correct.
/ Is this the law #10
I hold a CDL, I think I would have to disagree initially.
Here is Ohio's handybook, page 19 has a flow-chart, which based on that chart a CDL would not be required, assuming the GCWR is under 26001. Despite the fact that the towed vehicle is 10k+.
http://statepatrol.ohio.gov/doc/truckbook.pdf
/ Is this the law #11
Same in NY. as long as the GCWR is 26,000 or less and not for commerce a trailer over 10k can be towed with a regular class D license.
  • NYS license classes.pdf
/ Is this the law
Sorry but i'm well aware of the cdl rules the ticket was written for not having a medical card, no cdl is required in this case.Iam going to do some research on it Friday when I have time.
/ Is this the law #13
Not sure about Ohio or W. Virginia but NY only requires a med card for CDL licenses. Card is not required for non commercial licenses. Maybe the cop is trying to bend the law due to commercial plates on the truck?
/ Is this the law #14
Weight for 4wd 1500 truck is only around 5500lbs.
/ Is this the law #15
They do it all the time here in Maryland , BUT only if you are commercial , like pick up with a trailer hauling mowers . A 1/2 ton truck is a gvw at 7K truck and a dual axle trailer is 7K , so you have 14K lbs , you need a dot number and medical card . PERSONAL truck and trailer , you shouldnt need one . The main thing is you dont have to tell the officer where you are going , what you are doing , and definatly dont tell him you are using your tractor to make money .
/ Is this the law #16
As far as I know, your only required to hold a medical card for a combined weight over 10,001 lbs if your driving commercially. I am a non cdl, commercial driver, who has to have a med card for work. Work Truck weighs 14,000 lbs.
Last 1 ton dually I ran across a scale weighed in at 9,600 lbs. Add my wife and the kids..... well the driver would need a med card :rolleyes:
I'm thinking the cop was mistaken, and is probably gonna end up with lots of complaints to their boss. Cause there's a whole lot of retirees hauling campers, boats, and other stuff that would put them over that limit.
/ Is this the law #17
I'm assuming that dull was supposed to be dual.
My dually routinely weighs in at 8,000 to 8,400 when I pick up gravel. 11,000 + when I drive out.
/ Is this the law #18
I could see that happening here in Ontario Canada. Just more disguised taxation in the name of "public safety".
/ Is this the law #19
Virginia is the same as most states total gvw has to be over 26,000 lb and the trailer over 10,000lb but all is exempt for personal use.
/ Is this the law #20
Grocery Getter ;)
Truck weighs 6900~7000, boat 1800, trailer 600, motor 175, 20 gal diesel fuel (truck) & 12 gal gas (boat) 225, me 200+ (I'm being nice to myself) = 9,900# ~ !0,000# and we don't even have friends, gear, refreshments on board yet :)
