Hydraulic filter housing spring
/ Hydraulic filter housing spring #1
Nightowl66
NW. Ohio
Kubota B6200DT
I had to dismantle my mtd log splitter due to a crack in the reservoir. When I took off the filter housing the spring was loose in it. Anyone know how it is suppose to be in there? I don't see any other parts in there. IMG_0126.JPG
/ Hydraulic filter housing spring #2
You're missing the poppet valve, it allows the oil to bypass when the filter is restricted.............Mike
Thanks...It must not have been installed during assembly.
/ Hydraulic filter housing spring #4
That, or else it broke and is now in the bottom of your hyd tank...........Mike
/ Hydraulic filter housing spring #5
Unfortunately this is a all to common problem. I believe it happens during cold weather when the fluid is not allow to warm some before operating. The broken pieces can block the suction hose starving the pump or worse damaging the pump.
